+ Reply to Thread
Thread: ezstart help
    ohio
    21
    ezstart help
    Have a jato today tried tostart wand would turn moter no glow put new glow plug in still no luck?HELP
    May 2006
    Dayton Nv.
    3,149
    Check to see if the yellow wire to the block is not broken.
    ohio
    21
    Checked that too thanks can just one side of wand go bad?
    California
    4,752
    get a glow ignitor much better than relieing on the blue wire to heat the plug up. most if not all the time its going to be the blue wire if there is nothing wrong with your engine otherwise. take the blue wire off along with the yellow wire and use a glow ignitor and you'll more likely start everytime you want to if your tune is just right and nothing wrong with your engine.
    DEU 8:18 ESV
    May 2006
    Dayton Nv.
    3,149
    Quote Originally Posted by Irishman View Post
    What can happen is one of the pins where the ez start plugs into may have dropped down so it's not making a connection. check the plug to see if all 4 pins are at the same level and the 4 wires coming out of the plug.
