    Delaware
    1,178
    Reversing a servo?
    I finally got a 2.4ghz TX/RX combo and my servo now turns the wrong way. How do I reverse it? I went through the menu tree to "reverse the servo" and it reversed my throttle instead.
    Toronto
    2,330
    Do it again to reverse the throttle back to normal, then do it again but this time selecting the other setup. Sounds like you said, "steering.. reverse" and that affected your throttle, so instead go in to "throttle reverse" and see that that takes care of it?
    Alma, Michigan
    12,291
    Hold MENU for 3 seconds
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    Delaware
    1,178
    What do you mean "the other setup" krallopian?
    Toronto
    2,330
    I meant try reversing the other channel. You said you reversed steering but it affected throttle, so I was saying to do it the other way - reverse throttle, to fix your steering issue.
    Delaware
    1,178
    Ohhhh. I got it. That part of the tree is a little confusing lol. Maybe I'm just slow. I should have done 2-1-1 instead of 2-2-1.
