Results 1 to 28 of 28
Thread: slash upgrades
    Planet Vegeta
    651
    slash upgrades
    what upgrades should I use. I'm on a not tight, but firm budget. any recommendations?
    Springfield, MO
    3,686
    BL, lipo. Together.
    Then 32 pitch gears.
    Then big bore shocks.
    Then.... RPM parts in whatever you break.
    CT
    111
    One of the best thing I did was put windshield butyl in the diff mixed with a little grease. Around corners the inside tire lifts up and looses traction so doing this makes it work like a limited slip posi and you keep pulling through the corner.
    Planet Vegeta
    651
    i already plan on the shock (thank you ducati777) and im getting bl system, but which one best for bashing and racing?
    2,215
    Quote Originally Posted by f687s View Post
    The vxl system is good and castle systems are also very good.
    RPM in whatever you break except the casters. Adding on to what ducati said.
    Sarnia, Canda
    41
    I am a newb to RC and I also have the slash a 2wd. I'm just curios as to why switch to 32p gears? I got a method r Orion 15t and I'm having heat issues with the motor. Would dropping the pitch help? I just ordered smaller pinioned and spurs to experiment with. I would also like to know what should I upgrade to make a mean dirt racer. And what is BL?
    CT
    111
    Quote Originally Posted by DrakeButt View Post
    The 32p gears are probably less prone to stripping not sure just a guess. Adjusted properly your stock gears shouldn't have a problem. BL is short for brush less. If your having heat problems gearing can help and check for binding and just a tad clearance between the pinion and spur so they don't bind.
    Sarnia, Canda
    41
    There is No binding goin on I have tried all I can until I get smaller gears. I have the timing on the motor down to 0 with 16/86 gearing using 8.4v 3000mah batts. I make about 15-20 mins and the motor is 170degF almost. Thanks though
    Planet Vegeta
    651
    okay i have the bl sytem and shocks in my list, what tires should i use, and should i use beadlock or glue wheels?
    Planet Vegeta
    651
    just in case, do not mix the gear pitch, and here is a reference to help http://www.rccaraction.com/blog/2011...ood-gear-mesh/
    QLD, AUSTRALIA
    121
    I put one of these over my steering servo seen someone else Doit can't remember part number and Best upgrade for me was the RPM front Skid stopped the steering popping out of its holes all the time.
    greenwood cemetery bashplex 8))
    12,365
    Quote Originally Posted by ducati777 View Post
    BL, lipo. Together.
    Then.... RPM parts in whatever you break. Get alum c-blocks if they break
    Whats in my wallet?
    I cant afford a wallet...
    12,365
    Quote Originally Posted by wayke View Post
    Dcsally did this with revo servo guards.
    Whats in my wallet?
    QLD, AUSTRALIA
    121
    I never bothered with the shocks
    Titanium shafts when rear bent
    STRC caps on Shocks cause they were popping the cap off as it flexs
    Now have all RPM arms and Skids the shock position holes wore out scre levered its way out
    had an IDea to strengthen it for RPM and stock il get around to making it soon.
    Oh and the Proline chassis saver rear end is nice.
    SD California
    722
    Titanium shafts my rear steel shafts bent the first day out and I didn't run hard at all. titanium shafts hadn't had a problem yet.
    Planet Vegeta
    651
    okay brushless, check. shocks, check. driveshafts, check. what else?
    QLD, AUSTRALIA
    121
    Shock caps "STRC ST2267B" i believe the B designates colour.
    RPM skid Plate slash
    The rear skid had to dremel the edges to sleeve that rear bar holder back on snug as now
    Traxxas Titanium Nitride coated Shock shafts
    Planet Vegeta
    651
    thanks what else do you recommed
    newfoundland
    193
    TRX alloy casters 1++++ . RPM bumpers and low profile wheelie bar . strange no one mentioned the alloy steering linkage - I want that one . Proline protrac kit will help the suspension out big time .
    QLD, AUSTRALIA
    121
    Solid steering Bellcrank alloy yes for racing maybe but for Bashing maybe not a good choice to use alloy it puts stress on other parts and breaking 1 plastic piece from a hard hit is ok i guess but destroying a Nice alloy setup and the surrounding parts CRINGE NOW!.
    For me I like to Scrutinise over a basher drive til it breaks then upgrade but to a degree certain areas i avoid Solid parts like Alloy or Steel on:
    Arms "Good hit here and your bent and up for another set if you like 1 spare 1 bent."
    Hubs "The bearings do a Wonderful job on these fellas slopping around the bearings wear it "
    Skids "Bashing You turn them into what looks like poorly sand papered metal They don't flex back from 30 ft of AIR"
    Bumpers " Transfers most of an Impact into parts mainly MOUNTING HOLES AND WILL SHREAD"
    The chassis "Don't wan't to hit a Kid with a Metal RC if he decides to play catch"
    Never broken one would look nice when the wheels are off any benefit to a basher having them TRX Casters.
    Planet Vegeta
    651
    oh thanks so far. i saving up for these items now
    Get some sway bars because flipping is incredibly annoying.
    Planet Vegeta
    651
    probally stiffer shocks will do
    Planet Vegeta
    651
    now is the perfect time to get a bl system.
    Vancouver, B.C. Canada
    255
    WHY
    sdklvb
    Slash 2wd Vxl, ERBE; Crash N Learn
    Planet Vegeta
    651
    never mind now, i got a new brushed motor
    255
    get a brushless system you will be happey you did!
    Planet Vegeta
    651
    the time will come
