Results 1 to 11 of 11
    Philly area
    507
    need more traction
    I run Castle 2400 with 3s and 4s. Alot of pavement running (80%). I am destroying tires, mainly rears, i do rotate them. I know i have a powerful setup and i know pavement is not kind to tires. I balded my stock tires in about 20 packs. I am running streetfighters now and i can see the wear after a few 3s and 4s packs already.
    What can i adjust to make some better traction. I run 80wt shock oil and proline powerstrokes. I know the oil is heavy but it suits my driving and jumps without bottoming out to much.
    Kemp, TX
    156
    Maybe loosen the slipper clutch? This might keep you from spinning the tires so much.
    Philly area
    507
    With the power i am running the slipper literally smokes if it is not tight. I tried it already though
    Nov 2011
    Austin, Texas
    970
    A lot of people run the 2400 and use the slipper. You running the stock slipper or have you upgraded to the Revo? With any more power than the stock motor, you really need the Revo slipper.
    Philly area
    507
    Thought about the revo upgrade. Won't that give me more power to the wheels??
    215
    try hooking up esc and playing with punch control
    sunset beach
    324
    your are lucky your tires are lasting that long on the street
    Nov 2011
    Austin, Texas
    970
    No. A slipper absorbs some of power on acceleration by slipping. It reduces wheel spin which gives you more useable power and protects numerous parts of the truck including your tires.
    Quote Originally Posted by robdog View Post
    94
    what tires are you running?
    Philly area
    507
    First stock. They r bald. Now street fighters m2 compound
    Loosening my slipper a half turn it just screams
    El Sobrante, Ca
    7,880
    You need to learn some throttle control. Take off easy and you don't wear tires as bad. The 2400 system is just hard on tires. I have gone through a set since February 13 on my Ultimate.
