+ Reply to Thread
    Sonora, CA
    90
    Clicking when turning to the right.
    I'm not sure what is going on but when under hard turning tot he right the trust makes quick clicking sounds from the steering linkage. Its almost as if the servo is turning too far. Is there a way to correct this? Thanks.
    52
    http://traxxas.com/forums/showthread...071-Servo-gone
    this is a common problem. keep your eyes on the forum. i may have come up with a "gear preservation technique" for the 2080 servo, but only time will tell.
    Aug 2006
    Fairbanks, AK
    174
    What did you do? ^
    Sonora, CA
    90
    Thanks for the link, when getting a new servo do you have to do anything prior to installing it? Or is it plug and play?
    St. Louis, MI
    8,185
    Depends on which servo you get.
    In my opinion, the 390 is by far the easiest to install... all the stock hardware is used. Just remove the old, install the new, plug it in, and reverse the servo direction and you are good to go.
    390 Set Up
    All stock hardware is used.
    NONE of the hardware included is needed!
    There are tab braces that do not allow the servo gaurd to sit flush.
    IT IS OPTIONAL TO REMOVE THEM.
    I have done this both ways without any adverse reactions.
    Here is a picture of the braces:
    (thanks goes to danielhr77 for the picture)
    The tab braces create a small gap between the chassis and the servo gaurd.
    You will also need to reverse the servo direction.
    These are the steps to follow to do so for LINK:
    Hold MENU for 3 seconds
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    52
    Makg- im not sure i want to post til i find the cons. so far, it costs less than 50 cents and works just how i wanted it, but i dont want to release something in the pre-stages that will destroy people's servos even quicker.
