+ Reply to Thread
Results 1 to 17 of 17
    210
    Wheel hub dilemma aka getting rid of wheel wobble
    I am looking at solutions to the wheel wobble issue.
    Right now there are approx 20 wrappings of Teflon tape on the threaded part of the axel and there is still some wobble.
    I am considering removing the teflon and trying some heat shrink tubing next.
    Has anyone tried these:
    http://www.integy.com/st_prod.html?p...4#.T4ow3BB5lP4
    Or these:
    http://www.hpp-germany.com/factory-s...and-center-nut
    Option 2 looks awesome but will hit me with $120 Canadian after shipping and conversion, let alone potential duty...
    I might try the integy and mill some slots for the splines on the revo tires.
    I really don't want to drill the stock hubs and make an insert yet, I am just too paranoid I will not drill the hub straight and end up with a worse wobble.
    Nov 2011
    Western Kentucky
    782
    Hpp well worth the cash problem solved....
    Vs this didn't last long brass wears on aluminum hexes
    Wasnt a lot of work just drill the hex to fit the brass tube and tread the brass...but its a temp fix doesn't last long.
    ERBE,Losi 8ight,Slash 4X4
    kansas
    6,290
    I did the stub mod, I hated the result. When (if) I broke a drive shaft I had the beat the hub off the shaft.
    Switched to the HPI hubs all happy now...
    http://traxxas.com/forums/showthread...=1#post4909771
    19
    I purchased the integy wheel hubs. big waste of $20 IMO
    The thread in the nuts does not go all the way through which makes it very easy to cross thread, which happened first time I put them on. I haven't been able to find replacement nuts because the thread is unusually small.
    I bought the savage hexes, put them on only to find that there is still heaps of wobble, but then realised the the axial carriers are so warn the bearing is moving around! so I haven't used these either.. yet.
    I read in other thread yesterday, that someone has had the same brilliant idea as i did the other week. That is to cut off the stock wheel hub next to the hex part and use a nut similar to the savage ones.
    Dec 2009
    Pa
    769
    i run both the 6mm and 18mm offset hex from integy and i don't have any problems with them. i have ran them for almost a year
    Summit Dewalt Powered
    Revenge 1/8 buggy
    PEDE 4x4
    19
    Wow almost a year, that's a lot better then my -broke before I could use them, I have heard there are 2 lots of hubs made by integy. Does the thread go all the way from the front to the back of your nuts, like a normal nut?
    22
    Problem solved. A couple of nylon nuts voila no more slop.
    Dec 2009
    Pa
    769
    Quote Originally Posted by CanHasErbe View Post
    yes i believe they do. i am not at home to check though.
    Revenge 1/8 buggy
    PEDE 4x4
    Dec 2009
    Pa
    769
    Quote Originally Posted by OnebadTMAXX3.3 View Post
    just checked threads go all the way
    Revenge 1/8 buggy
    PEDE 4x4
    Nov 2011
    Western Kentucky
    782
    Quote Originally Posted by snap off racing View Post
    That's not a bad ideal.What about once you tighten the nut does the axle still move freely?
    22
    Quote Originally Posted by Brewers74 View Post
    Sure does. I still use a shim between hex and outer knuckle bearing. It does tighten the shimming slightly. You just need to recheck your shimming after tightening the nut.
    19
    Thanks, that's good to know. I'll be getting on to integy to find out why mine are made so poorly.
    19
    I'm wondering what I used to cut the hexes ? Would a hack saw work?
    59
    A hacksaw would work fine. They're aluminum, so they'll cut fairly easily. I would recommend smoothing/flattening them out on a sander to remove any burrs and make the nut easier to thread onto the hub.
    22
    Haha we're you drunk when you did it
    I used a lathe and machined it down.
    But you could use a hacksaw or a grinder. Whatever works as long as you are careful.
    19
    haha awesome. i'll give the hack saw a go =)
    kansas
    6,290
    ^ I don't think you will be able to keep it straight enough. Vise & a gringer or a dremel...maybe
