Results 1 to 30 of 30
Thread: Tmaxx to emaxx
    90
    Tmaxx to emaxx
    I have a tmaxx roller and I'm going to convert it to a emaxx. I have searched and did my research but I have yet to read about someone that has taken a emaxx transmission and mounted on the tmaxx chassis. I no it can be done so I'd like to hear from someone that has done it and what all it takes. I want to have good speed that's why I want the emaxx trans everything I've read with people keeping the tmaxx trans they haven't gotten over 30mph. So if someone can give me advise or send me a link Of the how to I'd appreciate it. Thanks guys
    2,197
    It probably bolts right in with little modification. I have an emaxx 3906 and the transmission looks like you could put it in many different cars.
    I think you should use the tmaxx tranny because then you would have two speeds and reverse. Just make a motor m9ount plate. They're easy to make.
    Sting like a butterfly and punch like a flea, jack
    90
    Everywhere that I have read they install a forward only gear and single speed mod. With a emaxx trans it won't have reverse?
    2,197
    Quote Originally Posted by cbark2305 View Post
    Oh sorry yes of course it will have reverse. All emaxxs have reverse since they are electric.
    Silly me.
    90
    What of I use the old tmaxx transmission. Would that have reverse? It's the esc that controls forward and reverse isn't it? I've been thinking and to save some money I will prolly just use the tmaxx trans.
    601
    I think you can use the T-Maxx tranny but the one-way bearing has to be modded solid so it will have reverse. Also the two speed auto shifting would have to be locked into a gear, I think. I know most electrics don't use multi speed trannies and I think it's because they can't hold up to the torque. The other problem will be mounting the motor to the tranny.
    I think the 3906 tranny will bolt in. It will be the easiest way to electrify the T-Maxx.
    90
    Well there's a place online where a guy builds the motor mounts for it they are only $20
    601
    Can you give me the name of the website? I'd like to see it.
    90
    how2rc dot com
    Feb 2005
    Good 'ol U S of Ayyyyyy!
    376
    http://www.how2rc.com/The%20T%20MAXX...c%20Power.html.
    Electric motors pack a lot more torque than a nitro engine so you should consider upgrading accordingly.
    Upgrade your diffs to EMaxx diffs or something comporable, and upgrade your driveshafts if you havent already.
    90
    thats another question what drive shafts should i use? i have steal cvds but what should i use for the center???
    2,197
    When your plastic ones wear out put cvd's there also.
    Any electric truck has reverse because the esc controls the direction of the motor.
    Those motor mounts on that website look good, but I think you could make one yourself.
    Feb 2005
    376
    I would use steel cvds down the center too. If you have the later model 4910
    driveshafts, those would probably work as well, the ealier model .15/ 2.5 models...no way
    They'd twist like pretzels
    90
    ok thanks guys.. yeah it was a 2.5 model i bought it used to swap to a emaxx only bc i got it so cheap ($35)...So what do u guuys think should i keep the trans in there or swap it out from a brushless one?
    QLD, AUSTRALIA
    121
    i've posted this in the nitro section too.
    90
    do you have link to how u did yours?
    QLD, AUSTRALIA
    121
    I did it on the fly last night harldy anytime at all. made a Block connector for brake and esc out of an Old RX, and the mount was from a storage shelf i had picked up a while back 19t pinion from a 4x4 slash and 52t spur from a random bag of tricks.
    1 dremel for all and set of hex keys. piece of nice white cardboard
    '4X' 3mmx50mm '8X' 3mm nuts several washers '4X' Nylock nuts.
    Quickest way get a screw the 4 bolts onto fueltank side line up you cardboard push it onto the nuts evenly to get the hole positions take off carboardgently and evenly,
    you want about 60mmx60mm 50mm high the corner section of a Metal shelf was perfect for this combo square couple of lines from the high side where the motor meets gearbox
    Measure 9mm down make sure its square
    Sorry if thats nonsense to you guys Soooo many energy drinks.
    90
    Awesome thanks. What about ur trans? Leave it stock or change anything?
    90
    Have u drove it yet how It run?
    QLD, AUSTRALIA
    121
    I just did a vid in vegas at 1/4 throttle need a Camera Man.
    http://www.youtube.com/watch?v=q7TxCWAEUn4
    thats the little guy running no shell.
    Stock tranny adjusted the shifter to change near 80% of Motor peak thats a Guess but hopefully thats right very very fun now.
    90
    Should I upgrade the differentials to the brushless emaxx ones? And should I swap to the brushless transmission? I may end up just swapping the chassis completely but haven't decided on anything yet.
    QLD, AUSTRALIA
    121
    Not sure what to replace yet will find out as different things break for different people and upgrading something because its there i see no point
    I upgrade things that warp or pop open from bashing so many spur gears on the 3.3 and engine mounts the rear tie Rods for me need an upgrade and stock shocks need the Alloy caps i pop them open easy.
    you guys could use a Flat Plat drill hole positions and bolt on a 3rd party motor mount I might do one up when i have some more $$
    90
    I think I've pretty much decided to swap the chassis and transmission to the brushless one. Trying to get one cheap from eBay. Also trying to sell the tmaxx chassis and transmission.
    QLD, AUSTRALIA
    121
    Any benefit from Switching chassis other than wieght ?.
    RC Turnbuckle Jr. RC-Fan's Avatar
    Jun 2010
    Miami, Fl
    6,649
    I would keep the aluminum chassi from the tmaxx, definitely more stronger than plastic chassis
    FLM - EMAXX
    QLD, AUSTRALIA
    121
    I've kep't mine no need for the EMBE chassis for now, Loaded up batteries in parallel 2s 5.2A ******* on the VXL seems to be quick enough with the Doubled the Deans surprised again at take off 2 deans per battery.
    52
    cool man looks nice
    The Transmitter
    30
    That's the 3500 Velineon and VXL-3s, correct?
    Ingenuity at it's finest, nicely done!
    Recovering Nitro Addict...
    2,197
    Quote Originally Posted by Bodaggit23 View Post
    yep ! vxl-3s
    QLD, AUSTRALIA
    121
    Just got the answers needed about my Trans il be doing the Revo Lock mod 2nd gear and clutch lock right now Getting rid of the Mech brake.
