I started my 1st upgrade to the new XL-5 Pede with the Protrac suspension upgrade.
I purchased Pro-Line 6062-00 (ProTrac Suspension Kit Slash) and a pair of Traxxas 3669A wheels/tires.
Thinking I can just go for it, I soon found I was having issues with getting the provided stearing and camber links to reach since they needed to be 11mm longer. The kit supplies more robust links and for a XL-5 the original rod ends are too small and too short to complete the build.
The rod ends to complete the build are Traxxas 5525 and come 12 in a package for about 10 bucks.
Since I didn't realize this, I took the correctly mounted arms off and rotated them to see if that would work. Not a chance and i was off to Snowfighter's house to see what I was doing wrong.
Well, he knew right off and looks like a road trip to find some rod ends will be needed in the morning :-(
Note: if this kit was going into a VXL then the original VXL rod ends would allow for the install to be completed without purchasing additional items.
From the kit I did install the front shock tower, which only required a quick removal of some plastic to allow the posts to be mounted. I also have the front arms mounted correctly :-) and only waiting on the rod ends to complete the Pede's first upgrade.
I'll get some pics up once done.
Don
.A shope in Kittery.Maine is open on Sundays.Hope he has the part i need.
