Emaxx 3906....when the front suspension compresses, the wheels both turn to the outside. The left to the left, and the right to the right. I've tried rearranging the turnbuckles on top, bottom, and every which way where they connect to the bellcranks and the knuckles and I still acn't fix it. All that did was make it even worse.
Is this normal? I want to make it so the a arms are flat, to improve handling, but I can't because when they get to that point the wheels are pointing out in opposite direction. It's not huge, but its enough to be an annoyance and prevent the truck from rolling good. And it will probably cause a ton of bump steer, too. Can you guys please help me out here? All of the parts including the turnbuckles are stock.
