Page 1 of 2 12 LastLast
Results 1 to 40 of 54
    Okanagan Valley B.C.
    734
    Stampede 4x4 CRAWLER
    Seems most people want to go fast with their pede's and I've done that so I got to thinking about crawlers and it made me wonder if a pede could crawl. . . . . moderately.
    So I bought a 55 turn motor and soldered the connectors off my dead Velinion to it and instaled a 13 pinion since that is what I had laying around
    Initial test looks good but I think I need a 9 tooth pinion since the motor got a little hot (160F) after about 10 min of horsing around.
    Also removed all the pre-load spacers to give it max articulation but I think I'll need to go back to the pede rear bumper instead of the slash one just for the crawl.
    Let me know what you guy's think.
    A couple pics and a short vid soon.
    O.S.21 Nitro Revo, Stampede 4x4, 2 Axial Honcho's
    Nov 2011
    Austin, Texas
    970
    Always good to try different things. Jang made a crawler with his shape shifter project. If you wanted to crawl even halfway decent, you need to lock the diffs and put some crawler wheels/ tires on it. Short course tires might work okay as well. A brushed motor is a good start for making a crawler.
    734
    If I could fit revo spools in her I would but my intention was more the quick switch since I have several motor plates.
    Then I could take out the 3s and the shock pre-load spacers along with the V-motor and drop in my crawl motor with pinion attached and my 7 cell NiMh.
    Not the perfect crawler but fun none the less.
    Maybe grease in the diffs instead of 50,000 wt.
    734
    And now for a short test vid, more to come for sure.
    Nov 2011
    Austin, Texas
    970
    Good idea with the quick switch motor plates. Probably would be too much trouble to dig silly putty out of the diffs when you wanted to switch it up.
    Sillion Valley, CA
    462
    Good stuff.
    How do you like the motor? You might as well invest in a separate motor plate so you don't have to switch them back and forth.
    El Sobrante, Ca
    7,966
    If you get a sensored brushless motor, you will still be able to get the low speed grunt. I had a Castle MMP and a Novak SC 5.5 in my slash 4x4. It crawled over rocks like a crawler and had more speed than the stock motor.
    Arizona
    2,199
    Tires are a great help those look to work great I love my trenchers.
    Rusty SCT
    Rusty LCG SCT
    Pede 4x4 SC8 *sold*
    734
    That's all good but I am using the stock esc and a $20 motor, the rest of the parts were just sitting in my parts bin.
    734
    Quote Originally Posted by AZ Racer X View Post
    Trenchers really are a "Do All" tire IMO
    734
    Test Vid #2
    -5* timing on the motor and 11/54 Pinion and spur.
    Think I might lock out Both diffs and switch to a 2s LiPo and a 9 pinion.
    144
    My approach to rocks on my pede is to hit them as fast as possible and just skip across them at full throttle.
    In all seriousness, I tried some rock crawling on my stock vxl, with new trenchers and it worked 100% better then the stock tires. Locked diffs would definitely help, as its easy to get hung up with that wide stance.
    Houston, TX
    627
    I had a integy 55t on 3s and the problem I found with putting crawler motors in the pede/slash 4x4's is the limitation to the 54t spur gear as the biggest you can get. You really need a spur in the 60-70's to get the full power (torque) out of a 55t motor. In theory you can mod the chassis and bulkhead to get a bigger spur but the spur will be exposed on the bottom and would have to fabricate a cover to protect it.
    734
    Quote Originally Posted by Koda Dank View Post
    Funny you mention that because I've been trying to think of a way to get more gear reduction but hopefully the 9 tooth pinion will help and adjusting the timing on the motor helped for sure. And what the heck, it's all in good fun anyway.
    So you don't think a 58 tooth spur from a Jato would fit?
    Houston, TX
    627
    no, the 54t is the biggest spur you can fit without modding anything.
    Arizona
    2,199
    Jconcepts also make a RocX tire that my friend has and it's pretty stellar for crawling. Very tall like the Badlands but has bigger tread like the Trenchers it has MUCH more cushion since it's a 2.2 and it a little narrower. Just another option for you. Good vid and yeah the 9t should do the trick with 2s and timing adjustments. . I LOVE your articulation of the suspension well done !
    Rusty SCT
    Rusty LCG SCT
    Pede 4x4 SC8 *sold*
    734
    Well for $3 buck's a piece I'm gonna see if I can fit either a 56 or 58 without exposing the spur on the under side and removing too much from the chassis.
    An 11/54 gives me 4.90909-1
    9/54=6-1
    9/56=6.22222-1
    9/58=6.44444-1
    Nov 2011
    Austin, Texas
    970
    The difference between the 54 and the 58 is negligible. Not worth modding anything if it doesn't fit. Silly putty in the diffs is going to make the most difference for better crawling.
    Aug 2009
    Hickory,NC
    146
    Instead of a crawler. How about a Rock Racer? To compete against the Wraith.
    It's adult proof, not child proof !
    Nov 2011
    Austin, Texas
    970
    Independent suspension vehicle would have a tough time competing against solid axels on the rocks.
    734
    Quote Originally Posted by Slaughter33 View Post
    Never wanted my pede to be a comp truck, just a little more flexible and with a spare motor plate and pinion on the crawl motor it's as easy as swapping the motor and pulling the shock pre-loads out.
    Still waiting on the 9 pinion and For 3 bucks I'm gonna try to fit a 56t with no mods.
    Nov 2011
    Austin, Texas
    970
    I know, I was responding to slopok's wraith comment.
    734
    What do you guy's think a about 500K diff oil vs Silly Putty?
    Houston, TX
    627
    silly putty is cheap and easy. its cheaper then diff fluid. 100k diff fluid is a pain to get out of the bottle. i can only imagine 500k fluid.
    i'd go silly putty. i locked a diff permanently w/ jb weld and im gonna do another one so i can have two drop-in locked diffs.
    734
    Finally got my 9 pinion and 2s Lipo, still waiting on the 56 spur.
    Switched back to the stock rear bumper for better approach angles.
    Ripped it up at the track in the morning and crawled some rocks in the afternoon.
    734
    Turns out a 56 will fit with no mods but the 58 was a no go.
    734
    Still haven't changed the diff oil yet but it looks promising for what I want.
    3S bashing in the morning and Crawling in the afternoon.
    This is just a test of approach angles and I'm sure it would be better with locked diffs but like I said I want to bash this thing at the track so I'm still on the fence about the Silly Putty.
    I've found that with 9/56 gears I get 2 hr run times out of my 2s 5000mah 20c with motor temps around 105f and esc temps at about 85-90f and that is with the lights on.
    The 56 Jato spur does fit with no mods however I did need to remove 1 screw from the center drive cover to get it in.
    734
    Test Crawl 3
    9/56
    2s lipo
    Badlands
    13,266
    That looks great! Check out the shapeshifter thread over at URC. There may be some ideas in it to help you out 8)
    Nov 2011
    Austin, Texas
    970
    Getting better with each update. Though, this video does make me appreciate the ability of my Honcho.
    734
    Seen all that stuff and Jang is great, but he did it with a $200 sensored brushless Novac system and silly putty.
    I'm trying to keep my bash-ability and crawl on a budget so a $20 55t brushed motor and the stock esc with heavy grease in the diffs works ok for what it is.
    734
    After trying all this I'm thinking about buying a honcho lol!
  33. #33
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,281
    Guys this is the Traxxas forum and only Traxxas vehicles can be discussed. This thread has had to be cleaned up because the discussion had strayed away from Traxxas vehicles.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
  34. #34
    734
    Bottom line is Traxxas does not make a "crawler" so as consumers we are left to spend our money elsewhere.
    P.S. The summit is NOT a crawler. And for the record DAD I'm still talking about my Stampede!
  35. #35
    N. Idaho... Da Sticks!
    3,397
    Quote Originally Posted by NITR0 newbie View Post
    P.S. The summit is NOT a crawler. And for the record DAD I'm still talking about my Stampede![/IMG]
    Well said!
    I have thought about doing something like this with my E-Maxx, I have a 55T motor in it now, but it would be sad to run it up against my XR10.
    I really think Traxxas would do really good making a crawler or scaler; and right now the 1/18 crawler market is just begging for a new truck!
  36. #36
    734
    Well said!
    I'm with you there, I'm a big fan of traxxas and their products but it would seem that they could do well by expanding their product line up just a little. If they were to make a scaler or crawler I'd be alll over it like a fat kid on a cookie.
  37. #37
    3,397
    As I have said before, it is ironic that Traxxas does not have a crawler, its Magnum 272 transmission was the standard until the AX10 came out.
    As for the Summit, cool truck, but here is as close as it gets being a crawler:
    I always thought Traxxas wouldn't come out with a scaler or crawler because those are nich markets, but then Traxxas comes out with the Dragster... Now I am thinking anything is possible. I was looking at the Dragster's rear axel, with a little reconstruction, it could be used for a MOA crawler axel...
    I am intestested in how far you can take your Crawler-Pede, are you planning on tweaking it more for crawling?
  38. #38
    i don't know
    551
    Jang also made a slash 4x4 crawler.
    Cars: erevo vxl, 1/16 summit, stampede vxl, tmaxx
  39. #39
    206
    Nice work with this. The long run time is probably the best part for me. The way you have it setup you could take it for a hike and have plenty of juice to spare. You still need to do something about those diff's though. I'd say silly putty because you can take it out if you change your mind.
  40. #40
    Jul 2012
    246
    try a summit bumper it looks cool and it isnt as far back as the wheelie bar and the slash bumper
