Results 1 to 14 of 14
    Portugal
    90
    Whats best for big joes tires, 65t spur or 60t?
    Hi guys i would like to know your opinion about this im going to buy a Slipper unit from robinsons and there are two options one is with 65T and other with 60T what is the best for big joes tires??? I have on my setup a 18 pinion.
    Best Regards
    Frederico ventura
    kansas
    7,823
    2s or 3s............
    Miami
    17
    Frederico,
    If you get a metal spur gear you must buy a Robinsons pinion too.
    The material of the pinion must be stronger than the robinson spur gear.
    Portugues? si te compras un spur gear de metal tienes que cambiar el pinion a un material mas fuerte, el mismo robinsons lo vende. No te recomiendo que uses un spur gear de metal porque si el no se rompe cuando debe romperse se va a romper la transmision y eso te costara mas caro. Saludos.
    Portugal
    90
    Hi 3s.......
    Portugal
    90
    Obrigado bono por acaso tenho um pinion de robinson 24 mas não deve de dar para esse set up das big joes.
    Miami
    17
    87 GN:
    Freddy already owns a 24 T Robinsons pinion and wants to know what spur gear is recommended using 3S Lipo.
    Freddy:
    Eu não posso lhe dar uma resposta, 87 GN sabe melhor.
    Portugal
    90
    Thanks again Bono lets wait for 87 GN answer.
    kansas
    7,823
    is this a test.........lol
    2/3s
    24/60
    reduction 2.5 : 1
    48,840 rpm
    65.72 mph
    24/65
    reduction 2.71 : 1
    48,840 rpm
    60.66 mph
    with the big Joes start with the 65.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    Isto é um Test... lol
    24/60
    redução de 2,5: 1
    48.840 rpm
    65.72 mph
    24/65
    redução 2.71: 1
    48.840 rpm
    60.66 mph
    com o grande Joes iniciar com o 65....
    Motor quente + cool esc = abaixo dos orientada.
    Motor frio + quente esc = mais orientada
    Tudo quente apenas para a direita...
    Motor ~ 180/190 * máximo F, idealmente 140/160 * F, temps podem ser 10 * superior dentro do motor
    ESC ~ muito bonito mesmo temps / fã vem @ 150 * F
    Da Lipo ~ 140 * F máx, idealmente 100/120 * F
    gl2u....
    Portugal
    90
    Thanks 87GN sorry about my questions but im a begginner. If i have the possibility to order other pinion what would you recomend , staying with the 24 or buying another size, is stock 18/65 a good choice ? this for bashing with big joes.
    kansas
    7,823
    24/65 at low 60 mph is a good start.. with 2/3s
    If I remember right you want the reduction to be around 3.0.. So with the 24/65 @ 2.71 : 1 it's close.
    Did you set the LVC to 3.4v per cell. How to in link #3..
    alot of good info read up as you have time..........
    AOD's links......
    Erevo 101:
    EREVO FAQ
    Lipo, LVC, Brushless & Battery charger/charging guides & purchasing links:
    TUTORIALS
    Refer to this to setup the Mamba Monster ( MMM ) esc for maximum performance:
    CASTLE LINK GUIDE
    Refer to this to find parts, upgrades, batts & chargers etc:
    USEFUL LINKS
    Direct from Castle Creations ( the esc manufacturers ):
    MMM FAQ
    Driver's ED Manual
    LED warning light meanings
    Portugal
    90
    Once again thanks for this valuable information. But just one thing im curious how do you obtain the mph that the car can give with that gearing? With reduction i understand you divide the 65:24 but how do you calculate to know the miles per hour?
    kansas
    7,823
    secret...lol
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    BrianG speed chart: play with the numbers
    BrianG web~site
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 mm)
    Rollout: 1.18:1
    Total Motor Speed: 48840 RPM
    Vehicle Speed: 54.76 mph (87.97 km/h)
    Effective KV Value: 2200
    KT constant: 0.61 oz-in/A
    Portugal
    90
    Thanks my friend ive learned alot with you.
    Best Regards
    Frederico Ventura
    kansas
    7,823
    you are welcome but, not all my info, I just have the links to others peoples hard work......
