Thread: I want one
    65
    I want one
    Where can I get a E-Revo Brushless for the least amount of money? I have a Rustler with the Velenion System, how would that work as a trade?
    Thanks
    Miami
    17
    send me a private message
    65
    About what?
    kansas
    7,580
    heheh I think he either has a truck for sale or is going to give you a place to buy one...
    Look in the MP there are a few for sale right now & they pop up every so often.
    Do some homework first..........gl2u
    65
    Its spring break! What is the MP?
    Jun 2011
    53
    MP= market place......3rd forum from bottom
    kansas
    7,580
    sorry here is a few more to look over, some have other meaning too....welcome to the forums
    no IDK (lol) all of them.......... gl2u
    Terms:
    BEC: Battery Eliminator Circuit
    UBEC: Ultimate (or universal) Battery Eliminator Circuit
    ESC: Electronic Speed Control
    BL: Brushless
    COG or CG: Center of Gravity. "Cog" could also mean motor cogging, but the letters are not usually all capitalized.
    CD: Center Differential
    MM: Mamba Max
    MMM: Mamba Monster (Max)
    MMP or MMPro: Mamba Max Pro
    RPM: Revolutions per Minute or the RPM company
    KV: RPM per volt motor constant
    Y or Wye or Asterisk or Star: A brushless motor coil configuration. Looks like the letter Y.
    D or Delta or Triangle: A brushless motor coil configuration. Looks like a triangle.
    CC/CV: Refers to the Constant Current/Constant Voltage threshold for lipo charging.
    CC: Castle Creations company.
    LMT: Lehner Motoren Technik brand of brushless motor, commonly shortened to simply Lehner.
    S, L, XL: Refers to the motor can length when talking about Feigao/Wanderer/Nemesis brushless motors.
    S&T: Sky and Technology company - makes the Quark ESCs.
    MGM: ESC brand.
    AC: Alternating Current
    DC: Direct Current
    PWM: Pulse Width Modulation. Refers to the method ESCs use to send partial power to a motor. Highly efficient. Can also refer to the signal from a radio receiver to servos/speed controllers.
    Rx: Receiver.
    Tx: Transmitter.
    RCM: RC Monster. Can refer to the main site, the forum site, or "the man" Mike.
    LVC: Low Voltage Cut-off device to protect the lipo cells from being discharged bellow 3V per cell
    HV: High Voltage
    FET: Field-Effect Transistor. High current devices used in speed controllers that channel battery current to the motor.
    MOSFET: Metal-Oxide Semiconductor Field-Effect Transistor. Other less common versions: Metal-Oxide Silicon Field-Effect Transistor, and Metal-Oxide Substrate Field-Effect Transistor.
    NiMH: Nickel Metal Hydride Battery
    NiCD: Nickel Cadmium Battery
    Lipo: Lithium Polymer Battery
    Cap: Actually not an acronym, but an abbreviation for capacitor.
    A: Amps. Electrical term for current.
    V: Volts. Electrical term for voltage.
    W: Watts. Electrical term for wattage or power. 1 horsepower = 745.7 watts.
    mAh: milliamp-hours. Battery capacity rating. How many milliamps a battery can deliver for one hour. There are 1,000 milliamps (mA) in one amp. So 1000mAh is the same as 1Ah.
    WOT: Wide Open Throttle
    Forum "shorthand" acronyms:
    IIRC: If I Remember Correctly
    ATM: At The Moment
    IMO: In My Opinion
    IMHO: In My Honest (or Humble) Opinion
    BTW: By The Way
    OTOH: On The Other Hand
    AFAIK: As Far As I Know
    FWIW: For What It's Worth
    FYI: For Your Information
    ATB: All The Best
    FTW: For the Win
    IDK: I Don't Know
    GL2U: Good Luck To You
    PM : Personal Message
    MP : Market Place
