Results 1 to 40 of 40
    Jun 2011
    Sydney Australia
    33
    Racing Ken Block
    I am looking to race the Ken Block! Is anyone else out there racing one?
    If so what set ups are you running? I will be running on ashphalt.
    I know I will need different tires? Any recommendations?
    Thanks in advance for the help.
    Jun 2010
    Lancaster PA....... NO i'm not Amish
    321
    You will want some sort of 1/10 touring car tire. The stocks wont have enough grip for racing. You might want to look into sway bars because the main handling problem is the high center of gravity. i Run 60w shock oil in mine and it's pretty stable at high speeds. But i just do onroad bashing that hints toward racing.
    MERV VXL + Rally VXL + Stampede Xl5
    Jun 2011
    Sydney Australia
    33
    Thank you, I will give it a shot. It will be interesting to see how it goes a) on the track, and b) against proper (Nitro and Electric) touring cars.
    Jun 2011
    Sydney Australia
    33
    FYI, for anyone that is interested.
    Borrowed my brother in laws 1/16 mini erevo, put touring car tires on, and dropped it. Went to the track and ended up racing a nitro 1/8, and a 1/10 touring car with a 5 turn brushless motor. Of course, I lost and these guys were both pros.
    Interestingly enough, I could pretty much keep up in the windy sections, it was on the straights that they killed me.
    woodstock .on.canada
    2,207
    keggo are you sure it was a 5 turn motor
    its just odd to me
    Jun 2011
    Sydney Australia
    33
    The guy that was racing the car, told me that it was a T.O.P, and that he had a hobbywing 5 turn BL motor. He also told me which club he races at and asked me to come down.
    He could have lied! But I will give him the benefit of the doubt, cause you should have seen the speed that he had on the back straight. He was seriously fast!
    I have since bought my own 1/16, and am waiting to meet him again.
    If you wish to see the track, google rc track at Whalan reserve, Sydney, NSW, Australia.
    Why is it odd?
    2,207
    im just not used to hearing 5t motors
    Dec 2002
    Sioux City Iowa
    189
    I'd recommend for a base line ON ROAD set up
    The 4.3 rate front Rally springs TRA7342
    The 3.4 rate rear Rally springs TRA7341
    Good set of tires
    https://www.facebook.com/groups/281683941894234/
    Jun 2011
    Sydney Australia
    33
    I have bought two sets of touring car tires, supposed to be the best. One are HPI and the other are Muchmores?. I have upgraded the pinion gear.
    Have been trying to get springs, but the local hobby shops have run out.
    Dec 2002
    Sioux City Iowa
    189
    i got my springs on ebay and had them in 3 days. look in the road racer section on the rally/ mustang , i did the drilled rocker mod and it works great with the stock springs. i did change the gears on mine, it was running way to hot i went to a 24/55 gears and its warm but not so hot i couldn't touch it.
    82
    will all touring car tire fit cause i'm looking for some foam tires but i don't know wich tires will fit , any advice ??
    Dec 2002
    Sioux City Iowa
    189
    any of the hpi 26mm rims with a 3mm offset will work and hpi X-Pattern work well
    Jun 2011
    Sydney Australia
    33
    I was told any touring car tire would fit, but check first! Mine are rubber tires.
    Have ordered the springs.
    Jun 2011
    Leeds, Yorkshire, UK
    47
    hi guys, I am running the KB but with a bigblock motor (Castle Sidewinder 5700kv) using sorex tyres 32's they give good grip but the car tends to roll when cornering at anything above slow speeds, any ideas for a set up to help with high speed cornering will be a BIG help, run mostly on asphalt bashing/ racing with friends, not sure if the sorex wheels/tyres are the best choice tbh as they are not as wide as the standard wheels
    Jun 2011
    Sydney Australia
    33
    All I have done is change the springs to tan. Seems to have helped.
    I have seen an aftermarket sway bar kit. I haven't bothered yet!
    Jun 2011
    47
    I have the swaybar kit fitted to a standard rally, but not the KBlock as it wont fit on the rear with the 540 bigblock motor fitted, are you running the standard motor/esc Keggo or upgraded 540?? only ask as not sure if the tan springs are firmer or softer than the standard white springs?
    Jun 2011
    Sydney Australia
    33
    At this point I have the standard motor and esc. I am looking at upgrading them....just not sure which combination yet. My understanding is tan is the next spring, followed by black.
    Dec 2002
    Sioux City Iowa
    189
    hey Keggo take a look here
    http://traxxas.com/forums/showthread...ker-wheel-rate
    this set up works great on carpet and tarmac
    Jun 2011
    Sydney Australia
    33
    maddenmaxx, thank you, I saw the original thread, diidn't see the latest stuff.
    I was debating whether to do the rocker set up. I'll be honest, I would be worried about stuffing it. Still may give it a go though.
    The spring set up is good though.
    Dec 2002
    Sioux City Iowa
    189
    its a lot easier then you think... i took one of the rear arms apart and used it as a guide , i screwed the rear holes together and drilled the front. or you can buy the hot racing rears and invert them with no trouble at all
    Jun 2011
    Sydney Australia
    33
    I'll give it a shot.
    I think i'll do it this weekend as it is supposed to be raining and I can't race.
    Jun 2011
    47
    Thanks for the info re the springs Keggo.
    I have been looking at the drilled rocker mod and might have a play at drilling a few holes on some old spare ones (while the HR ones I ordered turn up ) I also ordered a few sets of springs too Green,Tan and Black.
    I am going to run the rocker mod on the Mustang and the HR on the KB rally.
    Which springs are you running front/rear, got the standard set up on the KB rally and some Merv ??? ones on the Mustang (spray panted black as it was when I got it,set up rock hard and not very good )
    Dec 2002
    Sioux City Iowa
    189
    with the drilled rocker mod or the rear hr rocker mod in the front i used the stock green springs in the front and i run the 7341 tan springs in the rear
    May 2010
    663
    I thought the stock shock weight on the block was 80 wt? anyone know?
    Dec 2002
    Sioux City Iowa
    189
    it might be but i went to 5000 diff fluid works much better
    Jun 2011
    47
    so I want the green up front,tan rear and 5000wt all round, many thanks maddemax (with the Hr rockers )
    I have ordered 2 sets of the rear rockers did you run them in the rear as well ? what rate plates do you run on the rockers
    thanks again
    Stu
    Dec 2002
    Sioux City Iowa
    189
    i am running the h/r with what they came with , a #2 i believe and yes i did order a second set but was talked out of them by a friend. what are you running for tires ? i ordered 2 sets of these
    http://www.ebay.com/itm/4PCS-RC-1-10...#ht_1370wt_952
    as they come with molded foams that are stiffer then the tamiya foams i am running with the same tire
    Jun 2011
    47
    The tyres I am running atm are Schumacher sorex 32's from my tc and the HPI radial X's I was thinking or getting some foams but those you linked look interesting and are in the right price range too
    I might use the other set of rockers I ordered on the front of the Mustang or might lend them to my machinist friend to replicate so I have a full set for both
    77
    When I had mine, I ran the stock springs on the rear and the hardest aftermarket spring I could find on the fron.
    For tires (foams), I ran 35 compound on the rear and 40 compounds on the front.
    Dec 2002
    Sioux City Iowa
    189
    it is amazing on how much better the car handles now then when we first started racing them and how much the class has grown. there were only the 2 of us the first night then we had a few 18/t/r's show and some losi stuff now its a full blown 8 car rally class with more being added each week.
    Jun 2011
    Sydney Australia
    33
    I am running hpi x patern tyres and I also have muchmores.
    The hpi's are good and haven't tried the muchmores yet, but they are supposed to be really good.
    Jun 2011
    47
    The rockers and most of the springs I ordered have at last arrived (1 set of Tan springs on backorder), I just need to pull my finger out now and fit them to both cars,I have put 5000wt oil in 1 set of shocks and I am going to run the Tan and Green springs for now, I am thinking of going for a different set up for the other car to experiment with heavier oil and springs as It is running a 540 motor (unless anyone has a setup to recommend using with the big block motor)
    I will let you know how things progress
    Dec 2002
    Sioux City Iowa
    189
    that set up works well for me and most of the guys i race with...not sure with a big block , let me know how that works as i am getting one for my sons 5th birthday
    Jun 2011
    47
    as soon as we get a bit of good weather for testing I will let you know how it handles or doesnt I am hoping to get a bit of time this weekend for a quick carpark bash with a few of the local lads but it looks like we will be dodging the rain showers
    Dec 2002
    Sioux City Iowa
    189
    we are lucky we have a pub that lets put a track in the basement , here is one of our runs i am the orange rally
    https://www.youtube.com/watch?v=xODs...4&feature=plcp
    i don't know
    551
    Wow you lapped the other guys like 4 times. nice job.
    Cars: erevo vxl, 1/16 summit, stampede vxl, tmaxx
    Dec 2002
    Sioux City Iowa
    189
    to be fair its all in the setup...i have helped a few of the guys with my setup and its getting close...boy was i dumb lol
    Dec 2002
    Sioux City Iowa
    189
    well my son turned 5 today so he got a vxl rally for his birthday. i just got done setting up for wed night racing
    front shocks 5000wt diff fluid with traxxas 7342 black rally springs
    rear shocks 5000wt diff fluid with traxxas 7341 tan springs
    since he is so young i have it set on 50/50 geared at 19/55
    i have not done the drilled rocker mod as i want to try out the black rally springs on the front of his car , we will see how it handles this wed night
    May 2010
    663
    does the 5K oil make a huge difference with the handling? its not too heavy?
    Dec 2002
    Sioux City Iowa
    189
    yes it does, works great for on road i have seen a few posts of people using 7k - 10k oil but they are on a larger track with more top end speed
