Thread: Spur Gear Help
    Miami
    17
    Spur Gear Help
    I need help, I would like to know what spur gear and pinion size is recommended to use with the e-revo on grass with 6s lipo batteries (Traxxas 5000 3s Lipo 25C), a spur/pinion combination that would reduce the probabilities of the engine getting too hot and the spur gear going teeth-less.
    Right now I have
    -The stock pinion (I do not even know the size of it)
    and
    - 58T M 0.8 and 68T M 0.8 spur gears.
    Which is the combination recommended for bashing?
    kansas
    7,823
    if that means striping the teeth off the spur, then that usually only happens with a bad gear mesh or the motor coming loose.
    stock pinion IDB is 18T. So I would prob use the 58 spur. Would be a good start, but still abit under geared.
    try 18/54 or 20 ~ 21/54
    Diff ratio
    BrianG speed chart:
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 mm)
    Rollout: 1.18:1
    Total Motor Speed: 48840 RPM
    Vehicle Speed: 54.76 mph (87.97 km/h)
    Effective KV Value: 2200
    KT constant: 0.61 oz-in/A
    Miami
    17
    Is the stock gear (18/65) under/over geared if I use 6s Lipo 5000 25C?
    Miami
    17
    Thanks 87 gn, i learnt a bit from your post. I am trying..I am new at this hobby.
    I do not want my erevo to go super fast at the expense of more stress on the engine.
    I want a combination that offers the less stress using 6s LIpo.
    Pardon if you get a little bit frustrated reading my posts.
    kansas
    7,823
    all good^
    18/65 would be under geared. under geared will heat things up just like being over geared, the trick is to find a happy medium. Throttle control is more of a must with 2/3s. Follow the chart above & watch your temps & enjoy....
    temps gun is a must...
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F maximum, ideally 140/160*F, temps can be 10* higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F
    Lipo's ~ 140*F max, ideally 100/120*F
    Miami
    17
    OK, What is the happy medium of the E-Revo, using 6S Lipo?
    I just came back from running my truck, used the 68T spur and 18 pinion and the screws of the motor exterior around the pinion became loose.
    This is where I use my ERBE. Tropical Park Miami.
    I give it full throttle and then I make it jump that hill, it flies very high.
    kansas
    7,823
    you lost me ... the motor mount...
    http://traxxas.com/forums/showthread...=1#post4910702
    Miami
    17
    Thanks
    kansas
    7,823
    sure what did I do...lol
