    26
    transmission problems
    hello i am having some problems with my 4910 i thought it was the transmission but i replaced the transmission with a 3.3 transmission what started my problem was all of a sudden it started rapping out and barely moves i checked all the spur gear stuff and it is all tight and everything is connect correctly im stumped can anybody help..... i think it might be the clutch maybe i have no idea
    Usquam sed hic
    1,568
    Check the clutch, it's the only way to find out
    Matthew 7:7
    26
    what will it do if the clutch is bad
    26
    well i took my engine off and took the clutch bell off and the spring on the shoes was stretched out and the shoes were worn so i threw a different set in it that we had lying around and it seems to be a little better but not really sure still raps out pretty good i dont know if the ones i put in are wore down far enough to cause it or not i will try getting a new set and trying it.... does anybody else have any other ideas?
    Jun 2009
    Cocoa Florida
    3,970
    Loose slipper?
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
