Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 173
Thread: My tmaxx build
  1. #121
    Cocoa Florida
    4,002
    1000~2000 grt wet/dry sand paper to get as much of the scratches out as possible then Mothers mag & aluminum polish or Mothers Billet polish.
    Mothers Mag & Aluminum polish
    http://www.mothers.com/02_products/05100-05101.html
    http://www.mothers.com/02_products/05106.html
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
  2. #122
    Dawson creek bc
    1,115
    Ok thank you, I'll give that a try
  3. #123
    Jan 2008
    Sugar Hill Ga.
    8,383
    If its scratched a lot you will need to start with a more course sandpaper and work your way up in grit #. 1000/2000 grit will not remove most scratches.
    The polishing is the ez part, prep/sanding before the polish is the hard part.
  4. #124
    Dawson creek bc
    1,115
    Got my thunder chassis polished a bit. I'm just de anodizing my GA bulk set now. The FLM towers came in too
    I'll post some pics of it put together tonight. I'm also waiting for a order from UE. I'm gunna try out a monoblock with the thunder
  5. #125
    Jan 2008
    Sugar Hill Ga.
    8,383
    Sweet...
    Someone’s fingers are about to get sore from prepping and polishing GA bulks!
    Be sure to order the correct dog bone for the Thunder and the Mono.
    You may have mentioned it, but is there a reason you choose the flm towers over the knuckleheads?
  6. #126
    Dawson creek bc
    1,115
    I went with FLM because the knuckleheads only accept the older round body posts and the squared off ones feel stronger. If these don't last I'll try out the UE towers
  7. #127
    Feb 2005
    Good 'ol U S of Ayyyyyy!
    448
    Quote Originally Posted by Kyleb View Post
    Thats a good point. Squared posts are stronger than round,
    and the round posts are becoming difficult to find (new).
    My only issue with the FLM shock towers is....not enough shock mounting positions. j/k
  8. #128
    Dawson creek bc
    1,115
    I've been going at them a few hours now and this is shiny as they have got. Does the oven cleaner turn the anodizing black? I noticed I can kind of sand the black off. Anyone have a few tips
  9. #129
    Jan 2008
    Sugar Hill Ga.
    8,383
    With the application of the oven cleaner still wet on the bulks use an old toothbrush and hot soapy water to scrub the surface (wear rubber gloves or you will be sorry). Most of the black will come off with the scrubbing but you will need to sand the entire surface. If you want all the milling marks removed you will have to sand a lot starting with a rough grit working up to the finer grits.
    The GA bulks are one of the hardest parts I’ve ever de-anodized and polished, I feel for you.
  10. #130
    53
    Where did you get that chassis from. I have been looking for the FLM for the past year and i still can't find it
  11. #131
    Dawson creek bc
    1,115
    It's a UE chassis an it's waaay more common than the ice chassis. You can find them on eBay
    Made a bit of progress.
  12. #132
    Dawson creek bc
    1,115
    So this is my first complete tears own in about 3.5-4 gallons. This truck was filthy, I know most of you guys do teardowns after 1 gallon. I dident even know the axle carriers had bearings ! Between the fizz and axle carriers I did not have any bad bearings which was surprising. I pulled the rubber shields off and lubed them all
    Up
    I took my diff completely apart and dumped out the thick black stuff and filled my
    Diff cup with 7,000 wt diff oil, is that too thin? Greased the gears with some Traxxas grease. I also sealed the diff with RTV to be on the safe side. Dumped the stock 35 wt shock oil out and refilled
    With some 60wt ofna oil
    Assembled the one half back together
  13. #133
    27
    Sweet looking t maxx. I didnt know about the violator tank upgrade. I may do that to my maxx. I have a question tho. How much fuel does it hold in relation to the stock tank? More or less? I currently have a big aluminum fuel tank but i personally dont like it much. Its heavy and i cant see how much fuel i have left. That and i have to unscrew an aluminum cap to fill up instead of a pop top.
  14. #134
    Dawson creek bc
    1,115
    Quote Originally Posted by Joey_30 View Post
    The stock tank holds 125cc of fuel and the violator holds 150cc
    Everything you need to know about the tank would be in this link. Couple nice trucks in their too
    http://traxxas.com/forums/showthread...ng-the-upgrade
  15. #135
    27
    How much does the violator tank hold? Is it more or less than the stock tank?
  16. #136
    Dawson creek bc
    1,115
    It holds more..
  17. #137
    27
    Oops. Wow. Ok. Thanks. I may look into buying one. The mach 427 .26 engine i run on my max drains the stock tank pretty quick
  18. #138
    27
    When u get your 17 mm hub adapters try to make shure to get RED thread locking compound for them. Mine kept coming loose with blue. Dont put red on your regular screws tho. U wont get them back out even with tools
  19. #139
    27
    Oven cleaner eats chrome off of stuff.....i use purple power all purpose cleaner for my stuff
  20. #140
    Cocoa Florida
    4,002
    When you get your 17 mm hub adapters try to make sure to get RED thread locking compound for them.
    Mine kept coming loose with blue. Don't put red on your regular screws tho.
    You wont get them back out even with tools.
    The Violator tank is 150CC tank & stock is like 100 or 110CC.
    For very stubborn loctited screws use a soldering iron to heat up the screw head to get the loctite to break down to get the screw out easier.
    LiPo? Naw NITRO!!
  21. #141
    Dawson creek bc
    1,115
    Made some more progress. I cleaned up my engine and used a adapter sO I can run a BB header with a SB exhaust outlet
    A picture of the machines aluminum adapter
    Did the FL suspension and added a new savox hi tourque servo
    I had to drill new holes in the header do the spring would line up straight because it was a left side exhaust. bTW the ofna aluminum drilled out like it was butter
    Even with this engine and I big block header you can still see there is plenty of room between the shock and header
  22. #142
    Dawson creek bc
    1,115
    My monoblock and othe goodies came in from UE today!!
  23. #143
    Dawson creek bc
    1,115
    Making some Progress
  24. #144
    Jun 2011
    Michigan
    705
    Nice, like the looks of things so far. Wish I had the time/money to build the dream Maxx w/ everything I'd want in it
  25. #145
    Edmonton, AB Canada
    480
    Hey kyleb can you tell me the length of that mono block extension? Is it 34mm ?
  26. #146
    Dawson creek bc
    1,115
    31.75 mm ....
  27. #147
    Dawson creek bc
    1,115
    De-anodizing my
    Front skid, argh Xbox live can be so distracting..
  28. #148
    Edmonton, AB Canada
    480
    What do use to de-A ??
  29. #149
    Dawson creek bc
    1,115
    I'm using oven cleaner nAme yellow cap. Be carefule around screw holes, it does more damage that good
  30. #150
    Edmonton, AB Canada
    480
    cool.. then you polish it after? or just leave it?
  31. #151
    Dawson creek bc
    1,115
    Put my rpm wear plates on today
    I had to make a mounting bracket for the violator tank to bolt on. I had a STrc stampede skid Plate that was already chopped
    Up
    So I just used a peice of that
    <a href="http://s303.photobucket.com/albums/nn142/kyleb32/?action=view&current=6932A2B4-468B-4BF8-A5D2-B2677BDCF28A-287-000000608C30E8C3.jpg" target="_blank"><img src="http://i303.photobucket.com/albums/nn142/kyleb32/6932A2B4-468B-4BF8-A5D2-B2677BDCF28A-287-000000608C30E8C3.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
  32. #152
    Dawson creek bc
    1,115
    Well got my income taxx back. That means a lift kit and tired for my 1:1 truck, and lots of rc parts!!
    After dinking around I hacked my UE mount to fit the picco but the holes don't line up
    I decided to scrap the red dot and within the next few days I'll he ordering a .28 BB picco as son as I find out what flywheel and clutch I need.
    Along with some RRP steel tranny gears. Starting a second maxx project. It's a 4910 pro .15. I'll be putting this modded picco in it.
    It will be having all steel driveline and retain stock width and length. Should be stupid fast.
    Should have both trucks done in less than 3 weeks after I return from work
    UE mount hackjob
    How my new project is starting out
  33. #153
    Dawson creek bc
    1,115
    I just put a order in for a new gen2 widetrac kit from UE!
    I had no idea that when I started this, that this would turn into a supermaxx
  34. #154
    Jan 2008
    Sugar Hill Ga.
    8,383
    It only takes a couple of UE parts to make you want more.
  35. #155
    Feb 2005
    448
    Kyleb when you ordered your monoblock, was the rear driveshaft included?
    When I bought a monoblock from UE, I ordered the rear driveshaft at the same time
    and they told me it's out of stock. Now I'm staring at a 80 dollar paper weight.
  36. #156
    2,435
    looking good man... and yeah taking off anodizing is way easier with greased lightning.... but if you use oven cleaner what i do is soak it... come back and scrub with a toothbrush.. leave it soaking... toothbrush again... do this a few times.. then use the toothbrush and some water to get the rest off... there will be 100% no black or anything, and itll barely need any aluminum polish, even if you hand polish it to look like brushed aluminum... then if you want it really shinny use a dremmel polish wheel..
    ive de-anodized alot of parts.. and this method still only takes a few minutes to have your finished result look perfect..
  37. #157
    Dawson creek bc
    1,115
    Quote Originally Posted by NitroTrout View Post
    No the driveshaft is bought seperatly
    Luck you though! The website is showing them in stock
  38. #158
    Dawson creek bc
    1,115
    Quote Originally Posted by kuskye25 View Post
    meh, not
    Too worried about it. After its first run the whole truck will be tht color anyway
  39. #159
    Dawson creek bc
    1,115
    Parts came in.
    Some notable
    Things is a 2.5 tranny
    RRP 3.3 gears
    M2C 4shoe aluminum clutch
    MIP CVDs
    Lunsford turnbuckles
    Engine should be in tomorrow. Some strobe braces on the way too
    This tranny supposedly has RRP gears in it, got it off eBay.
    Now what spur/ slipper is on this?
  40. #160
    Cocoa Florida
    4,002
    Pull the slipper apart so we can see the inside.
    Looks like an RRP center & plates with a different MFG spur ring on it.
    LiPo? Naw NITRO!!
