ok so my summits evx-2 with lvd is just blinking green and wont let me do anything im useing the stock batts
and now its stuck in lvd mode and wont come out of it
It is sensing that the throttle is out of neutral range.
Check that the 70/30-50/50 switch is in the proper position.
its in the stock 50/50 position but i cant check because its stuck in lvd with nickle batts
I think you have to either use lipos to change it or drain the nimh battery so low that it will let you change it.
You can drive my car, but there's a $500 deposit.
i dont have lipos but ill try that
