Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    103
    hey their is a pro line runtime tank that holds 160cc although it dose not have a built in filter i stuck one in my fuel line sorry do not have a link
  2. #42
    Jun 2011
    Michigan
    704
    Most don't like that tank and actually prefer the stock on over it. The reason is because of the tall shape of it, which worsens the half tank lean issue. The main reasons people get rid of the stock tank and switch to the OFNA is because it almost fully removes the half tank lean issue, it's a little larger, and it has to be mounted further forward which keeps the wheels down by adding weight in the front.
  3. #43
    Oct 2012
    Milwaukie, Or
    283
    Oh Man I cannot say enough good things about the Improvements Gained by switching to teh OFNA Violator, It holds more fuel, Appears to eliminat completely the 1/2 Tank and under Lean issues, not to mention its pickups are set to pull every last drop of fuel out of tank, Also it is setup so when you end up upside down you have some time before you lean out and Die.
    Also I found (Thanks @Wildman4910 I believe) that the Balance is much better I hardly ever roll over now and I can jump Higher and further without getting Caddy Wampus. It is the second best Upgrade I have done.
    T-Maxx 3.3 :)
  4. #44
    Ontario
    265
    How do u guys flip the lid around ? Can't figure out how to remove spring ?
  5. #45
    Dawson creek bc
    1,108
    On top of the lid there's a screw. Loosen it and you can rotate it 360•
  6. #46
    Ontario
    265
    Quote Originally Posted by Kyleb View Post
    That just spins the nipple ? Don't u guys flip the whole lid around
  7. #47
    Jan 2008
    Sugar Hill Ga.
    8,339
    You can flip the lid if you want; I've done it on a few builds just to have the lid open in the opposite direction, but its much easier to just spin the nipple around.
    To remove the lid you have to pull the pin. You then have to install the spring and pin at the same time to re-assemble.
  8. #48
    Ontario
    265
    I've tried to pull the pin but doesn't seem to come out looks fatter in the middle
  9. #49
    Jan 2008
    Sugar Hill Ga.
    8,339
    It only pulls out in 1 direction. If you look close you will se the holes in the tank uprights are different sizes.
  10. #50
    Ontario
    265
    I got it out and flipped while I was at it I fixed my switch as well thanks guys
