Took my XO-1 for a spin around the parking lot .. Didnt crash into anything still with 50MPH pinion and as I got home inspected it . The front left wheel would make a clicking noise spun backwards none other wheels made that noise . So I took to my LHS they said its my differential . I thought its coming from wheel/steeringblock area . Anyhow get home take apart my diff everything seems cool no messed up gears , I notice the rubber ring gasket is torn around where the screw hole is . So after putting everything back still same noise .
Now trying to take apart at the wheels and see if somthing binding the factory put so much loctite on the sterring block hex set screw that it messed up two hex screwdrivers I had and is completely rounded out and have no idea how to get at it unless I drill it because its set into the block with no little bit sticking out to be able to notch it .. HELP![]()
