Results 1 to 11 of 11
    142
    65T 24T combo won't fit
    i've tried every combo pretty much possible for a 65T and 24T combo, it is just a hair off, any pics or suggestions?
    142
    it is too tight btw
    Apr 2007
    Valrico, FL
    1,679
    Quote Originally Posted by rcdude4051 View Post
    Never tried that combo but why fight it? 24/62 combo will fit with no issues and it only increases top speed by a few mph, not enough to notice without a radar gun.
    -ERBE
    -Slash 4x4
    Long Beach, California
    6,205
    that should fit fine. are you using single motor mount plate?
    | Rally GT8 Powered By CC |
    142
    yessir I am, it is all the way out i can take pics on my laptop
    142
    actually the manufactures sent me a 23T instead of a 24T so it is even smaller!
    142
    sorry for me being awkwardly in ths i didn't notice..
    6,205
    http://traxxas.com/forums/showthread...-(Spur-Pinion)
    check this thread, one guy said he is running 23t/65t combo with no issue.
    kansas
    7,820
    you did get a Hardened .8 mod 23T Pinion Gear with 5mm Bore (32 pitch) ?
    Just checking the pitch..
    21/54 is the sweet spot for 2s & 3s
    54 spur &
    21 pinion 2/3s 63.89 mph
    or
    21 pinion 2/2s 42.59 mph
    if you are running 2/2s a 23/54 in not to bad, but really watch temps.
    23 pinion 2/2s 46.65
    or
    23 pinion 2/3s 69.98 a bit over the top..........
    BrianG speed chart:
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 mm)
    Rollout: 1.18:1
    Total Motor Speed: 48840 RPM
    Vehicle Speed: 54.76 mph (87.97 km/h)
    Effective KV Value: 2200
    KT constant: 0.61 oz-in/A
    Jul 2007
    Rc Room
    1,484
    That looks like a MOD1 pitched pinion IMO.
    142
    what is a sweet spot for 2s and 3s with a 62T 65T spurr? I ended up using a 65T and 18T combo
