+ Reply to Thread
Thread: Diff shims?
    USA
    147
    Diff shims?
    Finally got around to replacing my rear ring and pinion gears. I expected them to look bad. There is no visible wear to my eyes. I'll replace them anyway. Question is, do I need to shim? I put two in and it was crunchy and tight. One shim gets rough on what seems to be a high spot. It sounds and feels best with no shims. Input welcome!
    ERBE, MERV, REVO, E-Maxx
    Nov 2011
    Western Kentucky
    788
    I just shimmed 5 one that was new even needed one it seems to help them out no play now on any of them.
    Tried using two shems but wouldn't hardly move so one worked for me just fine.
    ERBE,Losi 8ight,Slash 4X4
    UNknown
    4,283
    when i convert my revo diff to e-revo, i didnt put the shim cause its got too much gear rubbing/grinding when i closed it.
    USA
    147
    Ok. The other issue I have is with the pinion gear (hooks up to the center drive shaft). It has a lot of play. All my bearings and the diff housing look good. If I spin the shaft and hold tension toward the diff, the mesh gets really tight. Is this normal? I hope I've explained this clear enough. Thanks.
    USA
    147
    I put it back together and it works. It all seems a little loose. Just doesn't seem very robust. It's still the best RC truck I've owned.
    Jun 2009
    W Monroe, Louisiana
    1,972
    Just put a shim on the outside of the pinion shaft. That should keep it from moving in and destroying itself.
    USA
    147
    Quote Originally Posted by anr2442 View Post
    That makes sense. There is a lot of play there. Mine may require more than one shim. I'll do that next time I have it apart. Thanks.
