Thread: not fast enough
    Chicago
    12
    not fast enough
    my brushless is all stock and i have slipped in the 2 3s lipos. As i have read with these batteries it should do 65 right? well mine only went 52.3mph. so is it the gearing ratio or tires or what??
    144
    read the mamba sticker on the box u need 24pinion 54spur
    Jan 2009
    MI
    737
    Also, what are the batt specs? You must have at least a 3s 5000+mAh 30C (40C+ is desirable). Not to mention what growler87 just said: you need a 24 pinion and a 54 spur.
    Not enough space here
    Chicago
    12
    its the traxxas 3s lipos they are 25c. I will try the 54 spur and 24 pinion. thanks
    Chicago
    12
    where can I get a 24t pinion gear from that will work?
    kansas
    7,842
    change the last two ## in the p/n to the tooth count you want
    About any hobby store like Stormer
    Part Number: RRP8721
    Manufacturer: Robinson Racing
    Hardened .8 mod 21T Pinion Gear with 5mm Bore (32 pitch
    Chicago
    12
    does Robinson Racing have good reliable parts?
    15,573
    I have found their hardened pinions (12T & 13T, 32P, 5mm bore) to be very good.
    Alt-248 on the number pad =
    kansas
    7,842
    Quote Originally Posted by accarguy1995 View Post
    yes that is why I posted them..
