Results 1 to 34 of 34
    216
    Very happy w/tekin rx8 and novak 5.5 550!
    I finally got out to test my slash after the t-rce and motor/esc upgrades and I couldnt be happier! First off, the truck is almost impossible to flip, even on carpet. Secondly, after running 3 2s packs back to back the esc fan never even bothered to come on it was so cool. And the motor was only luke warm to the touch, and Im not even running a fan on it! The vxl would have gone into thermal shutdown no doubt! Now mind you its only 2s, and the gearing is conservative cause its a smallish track but still, very very good results. Should be a very good racing season for sure!
    Feb 2010
    El Sobrante, Ca
    5,208
    I also have the Novak SC 5.5. How are you geared? I am geared 17/54. I have a heatsink with a fan. On 3s it stays pretty cool.
    Slash 4x4 SCT 2400
    Slash Ultimate MMP 2400
    216
    Im 13/54. Truck just barely hits top speed on the strait. Our track is very tight, with a lot of jumps so acceleration is more important than hi speed.
    216
    El-sob, im thinking about messing around with the timing. Do you have any input or thoughts about timing that could help? Or should I just let it be?
    Feb 2010
    El Sobrante, Ca
    5,208
    I don't know about the.Tekin but the MMP can adjust the timing for you.
    Slash 4x4 SCT 2400
    216
    The tekin also does timing, and you can adjust where in the rpm range it advances the timing. I just dont know how much to advance it, or where in the rpm range.
    Feb 2010
    El Sobrante, Ca
    5,208
    I will try to do some research and find the sweet spot. I have mine on the stock setting with no extra timing from the esc. You could always try going up two degrees until you find what works best for you. If you do, let me know your results please
    Slash 4x4 SCT 2400
    216
    I have gone on the team tekin website and looked at the settings from some of their team drivers. Now none of them were running a novak motor of course, but some of them were running the tekin 5.5 turn pro4. They were advancing their timing by as much as 85% from ~6000-20,000 rpm's. I set mine at 50% from 6k to 20k. I hope to get some track time tomorrow, but they will probably be racing at the lhs, and I dont have a transponder, so I may not be able to run. You can always change to a lower profile at the track if your custom setting proves to be too much. You can chose from your 2 custom profiles, and 5 defaults, effectively giving you 7 profiles. All this without the need to link up to hotwire.
    Feb 2010
    El Sobrante, Ca
    5,208
    Let me know how what works best for you. It's supposed to rain here so I won't get much chance to test anything anytime soon.
    Slash 4x4 SCT 2400
    216
    Went racing today. The truck was amazing. If i only ran the 6 minutes, the motor came down cool. If I finished the battery off, the motor would only be warm. The truck was quick but needs some adjustment. I didnt have a transponder, but I started 1st in the second qualifier, and lapped almost the entire field. Never crashed once, it was epic. The winner had 24 laps so I had at least that. I think i need to swap out the 54 spur for the 52. Might add a bit more timing.
    Feb 2010
    El Sobrante, Ca
    5,208
    It sounds like it did you quite well! So you lapped everyone? Sounds like you have a winning setup! What batteries were you using? I am happy you have had such success with your setup
    Slash 4x4 SCT 2400
    216
    I just had a very clean run. Started with the lead, and kept it rubber side down.
    I am using gens ace 30c 4000's. They have a lot of zip for the first 3 minutes, then they soften up just ever so slightly. Most people wouldnt even notice. Over all, I am happy with them. If I go to buy more, I might try 40c.
    Feb 2010
    El Sobrante, Ca
    5,208
    Ok, cool. I am a Venom man. If they are working for you, by all means continue doing what's winning you races
    Slash 4x4 SCT 2400
    Kuwait / Charleston, SC
    205
    Hey ChrisG and El Sob, I've been doing a good bit of research and I'd love to invest in either the RX8/pro4 or the RX8/Novak 5.5. Before I make any rash decisions I wanted to be sure that I know which 5.5 you're referring to. Below are two links - both have Novak part number 3505. Is this the correct motor?
    http://www3.towerhobbies.com/cgi-bin...?&I=LXZUJ5&P=7
    http://www.teamnovak.com/products/br...550/index.html
    The Novak "retail price" of $219 had be pretty intimidated at first but then I realized it was $90 cheaper on Tower! haha
    I'm just a big hairy American winning machine
    Feb 2010
    El Sobrante, Ca
    5,208
    The link from Towerhobbies is the exact motor that I have. That is a great little motor! You will be happy with it. Just remember that you have to solder the wires onto the can. I think you will be very happy with it.
    Slash 4x4 SCT 2400
    Harrisburg PA
    176
    i have a novak 4.5t 550 wit 17/50 gearin
    Harrisburg PA
    176
    i like to use Thunderpower LiPo 2s n 3s 5300mah 65c
    alot of money but the power is dere n great run time....
    Lilydale, Victoria, Australia
    2,845
    You run the Novak 4.5t geared for a theoretical 57 mph on 2s and it does not get hot ?
    I find that hard to believe, that would be a super motor
    Novak recommends 13/54 gearing for 40 mph
    Cheers
    Slash Platinum
    Xerun 150 / Tenshock SC401 3500kv
    205
    Thanks El Sob, I'm dying to get the RX8 and this Novak 5.5! I just need a way to get it past my wife without her wanting to kill me!
    10
    I am new need a new motor does this work with the stock slash esc and will it fit in the truck with no mods.
    205
    From what I've read on other threads this motor does work with the Velineon ESC but it won't perform nearly as well as it is meant to. As far as fit goes, I'm pretty sure that you will have to move some stuff around because the can is longer than the stock 3500.
    2,845
    Stock ESC "should" be able to run the motor
    Some have had success but many have failed
    Problem is the fixed amount of timing added that cannot be changed (15 degrees)
    Be careful with any mechanical timing (on the motor can) and gear conservatively if you plan to give it a shot
    Cheers
    Slash Platinum
    Feb 2010
    El Sobrante, Ca
    5,208
    That is correct Ron! You need to buy the Stampede rx box and relocate it to the front of the chassis. Make sure you have the sensor wire all the way into the port on the VXL esc.
    Slash 4x4 SCT 2400
    205
    Oh yeah... I've heard people talking about the Stampede RX box mod and it looks a lot cleaner on the front end. Is this the correct box?
    http://www.rcplanet.com/Traxxas_Reci..._p/tra3628.htm
    Harrisburg PA
    176
    i have a double fan on my motor n a alum motor mount, so far it run good
    2,845
    So you are running at 57 mph on 2s with your current gearing ?
    Cheers
    Slash Platinum
    Harrisburg PA
    176
    i dont kno how fast my truck is running at dis time, but dis is the set up im workin wit ....
    Harrisburg PA
    176
    Feb 2010
    El Sobrante, Ca
    5,208
    Quote Originally Posted by big_RON View Post
    That is it! I don't remember it being that expensive. I have it on my first truck. Since I went with the Novak and the stock esc.
    Slash 4x4 SCT 2400
    26
    I have been looking into a new ESC and motor combo for a few weeks now. I've seen a lot of people with good things to say about the Tekin RX8 ESC and the Novak motors, on here and other sites. When I do a search for this ESC, though, it comes up as a 1/8 scale system. Am I looking at the correct item? I have almost decided that the setup discussed in this thread is what I will ultimately go with, but I would like to make sure I will end up with something I can use. Thanks.
    205
    You're looking at the right one. From what I can tell the RX8 only comes in one model. It got it's start as a 1/8 scale buggy sensored ESC mainly to be mated with the T8 motors. I think people started trying it with Tekin's pro4 1/10 scale SC motors and it later evolved into the RX8 and Novak 5.5 combo that we're talking about here. I believe its as popular as it is due to the tunability, small size and ultimatly high C rating that it can handle and dish out to your motor.
    26
    Thanks big Ron! Wow, they sure are proud of it! I was hoping I was looking at the wrong one and there was one that was a lot cheaper. May have to rethink things. I don't think the wife will let me get away with quite that much
    205
    haha, I know exactly what you mean, My wife will kill me! If you're a member of the super saver club at Towerhobbies.com you can get $30 right off the top with free shipping. Or its listed for $175 at TheBarnFloor.
    http://thebarnfloor.com/catalog/prod...oducts_id=2640
    26
    Thanks again. Maybe I can get it by as an anniversary present!
