Results 1 to 12 of 12
    USA
    147
    Pulls left on acceleration
    Does your ERBE pull left on acceleration? Mine has always done it somewhat, but lately it's gotten worse. I have set the toe and camber as close as I can get it to stock. I suppose it got out of wack when I broke a arms a while ago as well as a toe/ steering link. It has really become pronounced since I got some new SPC 2S batteries that have great punch. Any suggestions or comments would be helpful. Thanks!
    ERBE, MERV, REVO, E-Maxx
    144
    check the springs shock on both sides in the back make sure theyre adjusted the same
    mostly the spring load
    mine was off a bit because i messed around with the springs in the back
    adjusted them now its straight
    USA
    147
    Thanks. I'll check it out.
    USA
    147
    The rear rings were off a bit more than 1/16th inch. Is that enough to cause it to pull?
    Jan 2009
    MI
    737
    Check if the left wheels run as free as the right ones. If not, check for a bad bearing or if the Hex is in contact with the bearing.
    Not enough space here
    144
    Quote Originally Posted by bernomad View Post
    dont think so
    make sure the tires are even too
    Jul 2007
    Rc Room
    1,484
    Twist trim knob clockwise 10 degrees.
    kansas
    7,843
    BL torque .. enjoy it lol....
    all good info
    ~ trim adjustment
    ~ check toe F&R
    ~ check pivot ball(s) & caps
    they will back out every so often..
    aka camber
    USA
    147
    all good info
    ~ trim adjustment
    ~ check toe F&R
    aka camber
    Roger wilco. I spent some time on to and camber f and R. Its better now. Curious if this is related to a rear diff that is chattering that I'm putting off rebuilding. Work has been busy and interferes with my hobbies. I should be grateful. When I have my Talons mounted its most obnoxious. I have a track practice day/ Pre-season practice today. I'll see how it does on the dirt track with decent rims and tires.
    Thanks a million for the input traxxas forum folks!
    USA
    147
    Regarding pivot balls and caps, I often wonder how tight they can be without binding.
    kansas
    7,843
    Not very tight, it is a feel thing for me. I snug it (cap) until I feel it touch then back it off just a little bit. Then run the suspention (a arms) check for any binding.
    USA
    147
    You've described pretty much what I do. Thanks for the input. After going through the whole thing and not finding anything wrong, I rotated my wheels/tires from front to back. Problem solved immediately. I just bought 2 Talons mounted for the rear to match 2 that came with a Revo I picked up used. Wouldn't you know, one of the new tires wobbles like crazy. Not so much out of balance as it is mounted crooked on the rim.
    That is the last set of assembled rims/tires I'll buy. As much as I dislike gluing tires on rims, I think I can get them on straighter than whoever is assembling them at the tire factory in the sky!
