Page 31 of 34 FirstFirst ... 21 29 30 31 32 33 ... LastLast
Results 1,201 to 1,240 of 1359
  1. #1201
    Tampa Fl
    21
    $$ on rear diff
  2. #1202
    Jun 2003
    Estes Park, CO
    863
    I started my new merv build. I still got a good amount to order for the build though. I got the trans together though. HR case with HR gears all rolling on some yellow shield boca ceramics, held together with the rc screws kit an topped with a strc motor plate. Modded the case for the gears. The gears were epoxied to their respective shaft then lubed with P.T.F.E. grease in an attempt to keep them from grenading like my last set. All the hardware got some loc-tite love. Im thinking about trying to find some shims to take out the back and forth play of the shafts in the trans. Plus i wanna open it up again soon to see if the ptfe held onto the gears, spun the trans input up with my dremel to 10,000 rpm. If not I got a few more lubes to try.
    Dye-no-mite Pow-er Go Fast, Wirrrrr Screeeech BOOM
  3. #1203
    9,245
    i loved the sound of those gears but i think they do have a problem.don't think it's a lube problem though let me know if it holds up
    a lot of rotating weight too eats up some power!
  4. #1204
    Jun 2003
    Estes Park, CO
    863
    Had that happen to me too before. The little gear exploded, its cuz of the walls on the gear are too thin the bit of play in the hex and heat. If they made the center gear/shaft one piece then they'd be bullet proof. That's why I tried epoxying them this time around. It'll be a little while before I can see if it hold up though, still in the ordering process. Those gave out with your neu I assume?
  5. #1205
    9,245
    The worst way! At 60mph right when I nailed it! Locked the tires up luckily had foam tires so it just spun
  6. #1206
    Germany
    43
    i nearly finished my new body. it's a 1/10 scale body that trimmed so it fits on my merv with the new body on i could mount my "beast-fan" (8x8 cm) so the electronic runs cool
  7. #1207
    Baltimore, Maryland
    338
    Been working on a movie w 4 traxxas rigs featured. Will post soon.
    BB MERV/550 Rusty/OS21REVO
    Drive it like its Hot
  8. #1208
    Baltimore, Maryland
    338
    Oh yeah, n I switched my sonic 6.5 for a 5.0/6680kv
  9. #1209
    RC Turnbuckle Jr. Carbonrevo33's Avatar
    Jul 2008
    In a box on Hwy. 64 bashin' with Bradley Youngskins!
    3,979
    Can't wait to see it Mrmerv! I'm going to pick up some diff gears and 50K wt diff oil tomorrow, rebuild the rear diff and add the oil to the front diff. Bashing my merv and my friend's summit, and filming for my next short film will continue. I plan on making this one bad-a! I'm looking foward to filming/editing and sharing it with all of yall!
  10. #1210
    Rotterdam, Netherlands
    6,259
    Filled my shocks with 100WT Losi oil. I'll try tomorrow to see if it made it less bouncy.
  11. #1211
    Baltimore, Maryland
    338
    Swapped it a Sonic 6.5 for a 5.0. Went from 5480 to 6680kv
  12. #1212
    Jul 2008
    3,979
    I noticed your front and rear tires are in a different orientation with the tread, any particular reason?
  13. #1213
    Baltimore, Maryland
    338
    I've gotten quite a few comments about that I'm going to have to post a pic. I use to do a lot of mt biking n I have a directional in the front and a multi traction in the rear. If you flip the rear tire around one direction is for wet muck n the other for dry pack. I noticed enough of a difference under my own power to know it worked, very well so I keep my fronts directed n my back aggressive. I have center diff with a mild split so it works well with my sensored motor. Will post pic this evening.
  14. #1214
    Jul 2008
    3,979
    Cool, I figured it had something to do with extra traction.
  15. #1215
    Baltimore, Maryland
    338
    Shredded my center shaft. Time to install my center cvd's n re lube diffs.
  16. #1216
    9,245
    Heading of to go ride!
  17. #1217
    Jul 2008
    3,979
    Found out I snapped another rear bulkhead...
  18. #1218
    9,245
    came out of the mountains and my daughter decided to take a pass on the flats. one wheel took of by itself!
  19. #1219
    Ft. Stewart, GA
    593
    I know it's been awhile but I got a new body painted it then of course bashed in a random Parking lot!
    Sent from my iPhone4
  20. #1220
    Oct 2010
    Montreal, Canada
    400
    My Mini E-Revo with new shoes, body and wing!
    1/8 HPI Vorza Flux
    1/16 Traxxas E-Revo VXL
  21. #1221
    9,245
    Another expensive ride!
  22. #1222
    Pittsburgh
    728
    Finished installing headlights and tail lights. Then drove it.
  23. #1223
    Pittsburgh
    728
    Quote Originally Posted by Cipher_Jones View Post
  24. #1224
    Arizona
    83
    Installed my tekin 10.5T redline into my merv via traxxas 550/540 mount an HOLY SMOKES this truck has gone from controlable to ***IMAGONNAGOFAST***BBQWHEELIEACTION running a 30t pinion 50t spur combo with a 2s traxxas lipo but wow this is fast now.
  25. #1225
    flint, mi
    127
    stepped up to spc lipo 3cell.
  26. #1226
    St. Louis, MI
    8,185
    Started to tear it down for a new chassis, bulkheads, body mounts, body posts, differentials, and battery doors... but ended up just water proofing the BB 390 servo, shortening the ********* 60 ESC motor wires by about 2 inches, bridging the switch pads on the circuit board of the ESC -eliminating the switch, adding a shim to the front and rear differentials, replacing front body mount and posts, replacing just the rear body posts, checking the oil level in the YR shocks -only one was low, topping of the front, rear, and center differential, putting shrink wrap on the axle shafts to cover the slide, and lastly adjusting the HR knuckles.
    I have a few chunks missing out of the rear diff ring gear, and the pinion is wore enough to be sharp... lets see how much longer it will last with an extra shim in there.
    Still, this is my original differential after well over 250 2S packs and probably close to 30 3S speed runs.
    The old parts are wore... but not wore enough to cause issues yet. Once they do, I will replace them. Until then I will keep running them.
  27. #1227
    Tampa Fl
    21
    Preemptive tranny rebuild.
  28. #1228
    Oregon
    70
    Tore down the diffs, cleaned them up, reshimed, fresh greased. And working on putting a new ********* V2 ESC, and a ******* 4 pole, 4400kv, 380 can size motor. Just waiting on the pinion I want to get here now. Hopefully I'll be able to run the tires I want to ( Yokohama Geolanders on 2.2 Clawz wide offset )
  29. #1229
    162
    did a 20foot cartwheel and broke the rod end off of stainless pushrods. the plastic in those seem pretty hard. it was one of those "aww man" wrecks
  30. #1230
    206
    I see all this carnage and read all these comments and I can only say "what am I complaining for, I only cooked an ESC by using it on the wrong sized truck??"
    vxl3m on 3906 e-maxx in case anyone is wondering..
    1/10 Titan 775 bandit COMPLETED!!
  31. #1231
    My home, Squirrelville, Wild West
    631
    Started a tear-down, re-lube the need to lube parts, and put back together and bash-test.
    Only 70 MPH? MORE LIPO!!!!
  32. #1232
    Arizona
    83
    changed the rear shock fluid on my merv to 45wt with tan springs an modest preload, happy with the rough tarmac perfomance hope to give it a test run at SRS on friday's open practice.
    on a none traxxas note tested my mini T for the first time in over 4 years that made me happy aswell
  33. #1233
    Tame Valley, England
    27
    With a hard summer of bashing and my ESC dying, I have stripped the MERV down and I'm going to replace any worn or broken parts add a few upgrades and rebuild it ready for the winter.
    "If in doubt flat out"
  34. #1234
    9,245
    took out my gps from a 65mph cartwheel. flung it 20' in the air . had velcro and a zip tie on it but was no match
  35. #1235
    Oregon
    70
    Finally finished my rebuild with the new motor and ESC......
    Road test to follow soon
  36. #1236
    palmdale, ca 93552
    4
    cc 10a bec, 4s, proline road rage and titus beadlocks.......70+mph wheelies.......
  37. #1237
    106
    Quote Originally Posted by IRgeek View Post
    Beautiful looking Truck, I finally got my merv out for a drive to stretch its legs, wholly eff its fast. Was soooo not a good idea for my 6 year old as a first buggy. Unfortunately she loves it way more than our stampeded and said she much prefers it small because she's smaller, allafter I ordereded her a 1/10 30th anniversary grave digger for cmas
    OH well, was pretty impressed, but have a lot to learn with rgards to driving it and tuning it, had a hard time keeping it rubber side down.
  38. #1238
    532
    Tried to break it.
    Not by smashing into anything, but give it a pounding to see what gives. I already have a stripped rear ring gear & hoppin up most stuff so what the heck.
    Aside from the diff nothing gave out. Did jumps off a ramp on concrete, not high, about 4 foot nice flat landings, a few nose up, a few nose down, a backflip. All gravy, some wheelies, stripped gear noise aside all held up, flipped it rolled it over and over and all is good after inspection...
    Now time to fix the weakest link, darn poorly designed diff cases.
  39. #1239
    9,245
    I had to replace my exotek shocks with my hr shock bodies to make room for my neu 1112 so I figured I would beef them up. Rebuild and some tin-coated shafts
  40. #1240
    Arizona
    83
    boiled my glued set of wheels an slapped a couple onto my first half of axial AX08061 beadlocks. Have a small nylon "bushing" on the axle to make up the shaft size difference between mini revo 4mm an XR10 7mm
