Hi Guys
I am running 2S 5200 Team Orion Lipo on 18/54 gearing. I am also using a cover for the E Revo Brushless in order to reduce cleaning effort.
Happy with the speed but the motor is hot at about 94 deg C or 207F at the end of the run. I am just running the Erevo on tarmac carpark. I was thinking it could be my temp gauge is not calibrated properly. Assuming my temp guage is correct, what can i do to reduce the temp? Is the castle creation blower effective?
I also got some battery questions. If the battery stops charging at 4.18, 4.20 is this acceptable? I am charging at 2.0A only. When charge at storage, both cells showing same number at 3.85. For my 2S battery, I also notice that when I charge them at storage after my run, the battery is showing 3.55 3.56 and 3.40, 3.42. I thot that 1 of the battery was weak. However the following week when I run and charge at storage again, the "weak" battery was showing up as 3.55 3.56 while the other battery was 3.41 3.42. Does the Erevo draw power evenly?
I also got a 3S battery and it finished charging at 4.15, 4.17, 4.18 at 2.0A. Battery already damage? If i continue to use it on the Erevo, any issue?
Thanks all for your advise.
might just need to take the cover off, for more air flow.. air compressor or leaf blower for clean up.
