Results 1 to 11 of 11
    162
    How do I set - Multi-function knob
    how do i connect the multi fubction knob on the new tqi 2.4 ghz transmitter to do the throttle trim like the older remotes... Thanks
    2WD Slash Vxl W/ Venom 2cell LIPO 7.4v 5000Mah 20c
    15,722
    Turn Transmitter ON
    Press/hold MENU button
    --green LED blinks
    Press SET button
    --red LED blinks
    Press MENU button 4 times
    --red LED blinks (x5)
    Press SET button to select
    --green LED blinks (x8)
    --returns to driving mode
    Alt-248 on the number pad =
    Alma, MI
    12,283
    The TQi has the same menu tree?
    Melbourne, Aust.
    69
    Yep, exactly the same as a 2.4 link. Except for the dock, its the same buttons, same blinking lights, some of the internals are the same. Therefore, a tqi without the dock is functionally the same as a link, so its only worth buying if you have the phone.
    15,722
    The instructions came from the Slash-with-TQi manual, so it seems they have the same menu trees.
    Alma, MI
    12,283
    I did not think to look there... I was looking in the download section for the remote itself.... no real manual there yet.
    15,722
    Yep, I did that too. It will come, I'm sure, but for now we'll all just have to check the full vehicle manuals.
    162
    Ok I got it to work. But what else can i have that knob do(not using docking base) Thanks for the info
    Alma, MI
    12,283
    Which model did you buy that came with the TQi?
    Or did you buy the TQi separately?
    This information is in the manual...
    Until it is posted in the downloads section, you are going to have to find a model that comes with the TQi and read the section about the TQi.
    15,722
    Depending on the model I'm driving, I use the MFK as steering sensitivity or braking strength. Or others.
    carriere, ms. us
    54
    Hi Ppl Is it easy to set the steering sensitivity with the new tqi tr/rx set up. The steering on my 4 tec is way to sensitive. thanks
