    My two velineon vxl-3s exploded
    Hello guys I am the owner of one slash 4x4, I running with 13/52 (no 54) gear, 7 cells 5000mah nimh battery and center differential. I live in an always cold place with like 50F.
    A couple of days back I was bashing and when the battery just started to shows that was going to empty, the esc just suddenly off, no led no nothing, I checked the temperature of the esc and was really high so I thought “crap” I blow it up, I waited a couple of minutes to let the motor and esc got cooler, then I put a charged battery and the vxl-3s started to smoke and totally blows up.
    I bought my slash last december so my 30 days guarantee expired, a couple of days after the esc problem, I received my new slash 4x4 ultimate with the TQI, so I just removed the esc from the new one and installed on my older slash (I know probably a bad idea) because on the !old! Slash, I spent a lot of time with suspensions, sway bar tuning, rpms parts etc. I checked the motor of the old one first, I disassembled it , toke a look of the rotor ,the bearings the internals coin , tried to found some signals of short circuit and the motor seems fine to me.
    I connected , tried easily off ground, no high temperature no strange sounds, so I go out for another bashing session using my other battery and after 20 minutes of really good bashing ...weird... ,again the same thing, the esc just totally off, I waited put another battery and again it blows up, lot of smoke…..
    So I stared to got mad, what the heck is blowing the escs, the batteries are fine, the motor is fine, is just one of those murphy things and I got two defective escs?.
    I can buy a new vxl/3s for around 90 US and I can send the other one for warranty, but I was just thinking buying two castle sidewinder sct each 120 us, my nimh batteries are mostly new and I want to wait a little bit before going to 2s lipo.
    Wife authorized like 250 US , So fellows what do you suggest me to do.
    Houston, TX
    627
    i would suggest the mmp 2400 $199.99 USD its an awesome system but 3s-4s lipo
    Dec 2006
    camillus, ny
    2,560
    Quote Originally Posted by Koda Dank View Post
    X2 castle makes good stuff.
    Man i need more than 50 characters.
    El Sobrante, Ca
    8,136
    There could be a problem with your motor. That is too weird.
    St. Louis
    380
    Mamba max pro sct 2400
    Racing in the Past, Present, and Future...MAYBE
    Oct 2011
    Worcester, Massachusetts
    1,398
    hahahahaha everyone says the castle 2400!
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    Hummm so here some points:
    • I have my two slashs begging me for a fix.
    • The ultimate never had the change for a first ride.
    • The warranty thing about one of the escs is going to take a while
    • I could use the lifetime warranty for the other escs but it would cost me 50 usd + shippings .
    • I have one never used velineon 3500 and the other one, shamed, probably but not proved guilty of my misery.
    • Over budget means the use of dark or underground untraceable pay methods, and at the end she will know .
    • I think 2400kv is just too mush torque, it will definitely need 3s lipo, rearrange the receiver to the front, I will need to go back to slipper clutch and probably is going to break something else
    • Any lipo options means probably 180 usd , two lipos + charger and I want to be !!green!! and use my 5000mah nimh batteries until their lifetime.
    So what about :
    • Mamba max race pro /3800kv – 200 usd + sidewinder sct/sv2 esc 60usd + ( 4mm bullets, traxxas hc male, 5m pinions pack) 25 usd + shipping = something like 300 usd
