+ Reply to Thread
Results 1 to 39 of 39
    Delaware
    1,177
    Locking a differential?
    How bad would locking my differential hurt my steering? I know it really makes it hard on a 1:1 truck. Also, how would I do it, or is it impossible?
    To the men and women of the US military, thank you
    Sep 2010
    middle o nowhere Ill-inois
    728
    I have only done it on a monster truck. 5 inch wheels. It doubled the space needed to turn 180 at most speeds but this truck runs a 27 turn motor so it is more of a crawler. is there any particular reason you want to do this? Does it feel like your rear drive is biased to one wheel or something?
    Pede 4x4, Pede VXL, Rustler VXL, LNC, Wheely King
    Sep 2010
    728
    I meant to add I have seen threads on changing diff grease can change the action of it making it more "posi" acting. Right now I can't find any specifics on it.
    2,188
    There is a very simple mod that can be done to your diff to lock it....but don't do it.
    I did it and I completely destroyed all the gears in my transmission.
    Delaware
    1,177
    I am just tired of getting hung up on stuff. I just bash around my back yard and in the woods, and I am always getting hung up on something because one wheel is off the ground. I think I'll just tack weld the two shafts together at the bottom that come out of the case (not sure if they have a name). I have backup parts if it doesn't work.
    Arizona
    2,088
    Yeah Silly puddy works wonders for locking your diff. But yeah your turning will suffer greatly. if you want to make it stiffer just add some thicker grease to it. At least that option you can change back without destroying something
    2,188
    DON'T weld your parts...if you are insisting on doing this I can tell you how to do it with minimal damage to your parts.
    2,188
    Quote Originally Posted by AZ Racer X View Post
    When I did mine, turning did not suffer hardly at all.
    Sep 2010
    728
    Get some talons or something along those lines and run some 19 86 gearing like a stampede. I set mine up that way sometimes it can be pretty fun in a rough area. Ever done anything like that?
    Elyria, Ohio
    191
    Quote Originally Posted by upbasher View Post
    Don't you flip some gears around????
    2,188
    Yes thats all you do, but you have to do it just right. (The little spider gears inside the diff)
    And it involves dremeling....but your diff will be locked for ever.
    Nov 2011
    Heflin AL
    413
    I know this is a little off topic. but I run 2.2 pro-line dirt hawgs and they balloon bad. how much will it help my traction if I tape the tires?
    Arizona
    2,088
    Ot - TONS.
    upbasher - you got lucky then or you just power slide through it.
    Delaware
    1,177
    Do you adjust the position of the planetary gears so that they mesh across both gears attached to the output shafts? Thats what I was considering doing.
    Rockhampton Australia
    294
    I bought a diff lock on a website you just pull the spider gears out and the shaft and it slides in and locks your diff was like 12 bux turning did suffer tho.. But no more one wheel driving faster then the other and spinning my car out anymore, I think it's from hot racing
    I am here: http://maps.google.com/maps?ll=-23.279002,150.512595
    Missouri
    50
    Quote Originally Posted by Pandee View Post
    How bad did your turning suffer? Cuz I am thinking about doing this!!!
    Rustler VXL
    Yours goes how fast???
    2,188
    Quote Originally Posted by TraxxasTuesdays View Post
    That is exactly what you do.
    orlando, fl
    141
    That may have contribute but I don't think its all that. I run stock duff's, locked different and everything in-between. The gears seem to be casted, not machined so they are going to break.
    I like locked duff's, but drive train will suffer on stock parts. No matter what you run the drivetrain will wear out a little quicker.
    I say go for it. The locwasher is OK, but wore out and started to act normal again.
    The CA glue in different works great but you have to be careful. It puts out fumes when drying and you have to make sure its true when you glue it.
    Sent from my LG-P509
    Stampede xl
    Xxxl 1/5 in the working.
    294
    Quote Originally Posted by RC4LIFE53 View Post
    Not as bad as I thought, but you do notice it. I love it tho saved me alot of unneeded sideways action from one wheel spinning faster than the other.. Just remember if you get one you need to thread lock the grub screws that hold your shaft or it will spin freely.
    I am here: http://maps.google.com/maps?ll=-23.278907,150.512725
    Central Massachusetts
    50
    I used to clean the grease out and wash it, drill two little holes the size of the tip on a tube of super glue (one hole is for a vent to let the air out) in the side of the cover opposite from one another and shoot super glue in it untill it comes out the other hole and Bam ! Instant Krazy Locker. It works every time. It does affect the steering a little but you just compensate by sliding the rear out with a little more throttle.
    Arizona
    2,088
    90k diff oil done hehehe
    Washington State
    624
    Yea...I would honestly just use thick diff grease, pack it about 85% full (if you pack it FULL it will push out and start gooing out of your yolks. And...are your ready for this...some Badlands. Do some searching on em, they're sworn by for off road stuffs. And they're about 5" tall so they'll give you good clearance. I'm running talons and really heavy grease (Grim Racer speed grease, for marine but works great) in my p2de and only time I get hung up is high centered. It's not a matter of extra parts, if ya fully lock it things will break. If you WANT to fully lock it just get the hot racing thing or put putty in your trans so theres at least some give if things get hairy.
    P2de VXL - Summit - Mini 8ight
    Delaware
    1,177
    I just packed it full of the heaviest grease i could find. Its Mystic high temp grease that I use on the bearings on the trailer for my 1:1 race boat. I lost all my set screws for my pinions so as soon as i get some, I will see how well it works.
    Arizona
    2,088
    Keep us informed And good luck.
    South of St Louis
    5,024
    When I want heavy oil in the diff I use Bad Horsie diff grease. That is some thick stuff and it doesn't leak out (I should buy stock in their company for all the times I suggested it).
    Missouri
    50
    So I should use some thick diff grease to play it safe??
    Rustler VXL
    2,188
    Thick diff grease will definetely be a better idea than completely locking it.
    Delaware
    1,177
    I stole a pinion out of my slash and ran my Rusty today. Packing it full of grease seemed to help a little. It seemed like when I got one wheel off the ground or in a position with no traction, I could finesse the throttle and get enough power to the other wheel to make it work. I guess if I want a crawler, I need a crawler. I'm not sure if it was just my perception or not but it seemed like the effect got less and less. I may have been getting more and more used to it though.
    Jun 2010
    Australia
    363
    You need one of these
    I ran one in my Rustler for about a week until I took it out.
    Slash 4x4
    Spartan
    Stampede
    Rustler x 3
    176
    Do the washer trick between the planetary sun gears, i used the little washer they have behind the shock screw where u attach it to da tower. Check out ultimaterc rustler section, look up posi diff mod. I run trenchers and its made a big difference in the loose stuff.
    294
    Quote Originally Posted by Troy711 View Post
    That's the one
    Arizona
    2,088
    How thin is people's grease if they are having this issue ? What's the stock weight ?
  33. #33
    Delaware
    1,177
    Mine had just a little light weight grease in the corners... not doing anything for the gears, so stock they have pretty much nothing in them.
  34. #34
    Arizona
    2,088
    Eek. Mine locks up great. Can't remember what I used though lol.
  35. #35
    66
    Washer mod here; like it. Really good 'posi' effect. You will need to replace the washer every so often though.
  36. #36
    Dec 2009
    337
    Why did you take it out?
  37. #37
    Jun 2010
    Glendale, AZ
    156
    I run 500k weight in mine and it is hard to control in loose, flat dirt, such as a baseball diamond or open field. I usually run in sand and thicker places with brush and grass and 'heavy' dirt so the posi traction helped. I can still spin just one tire from time to time though.
    Rusty VXL W/ Sandrail Chassis (Coming soon...)
  38. #38
    Jun 2010
    Australia
    363
    Quote Originally Posted by scootroc View Post
    Cos it was rubbish to drive. You gave it the slightest throttle and it would spin out.
    Slash 4x4
    Spartan
    Stampede
    Rustler x 3
  39. #39
    Dec 2009
    337
    Want to sell it?
