Results 1 to 2 of 2
    50
    Differential housings...
    Over the weenend I finally opened up both diff housings, cleaned, oiled and cleaned and re-packed bearings. I had noticed that my front diff had been leaking and I think I found the cause. The blue seal on one of the spider gears had failed. When I looked up the part all traxxas offered was the complete housing with the seals. Can anyone find just the seals? Or have any other advice to seal up the housings?
    North Florida
    676
    as far as I know, the only way to get them is in the complete kit with the plastic housing, the two seals, the one teflon washer that comes with them, and it also comes with a new seal/gasket that goes between the plastic housing and the ring gear
    TRA5381
    fix, run, break, repeat
