+ Reply to Thread
Results 1 to 11 of 11
    1,718
    Front and rear wheels?
    Are the front and rear wheels the same? Im looking for a new set of wheels and tires. And some of the wheels i have found say they are for the rear? The stock wheels all look the same?
    St. Louis, MI
    8,377
    You want rear wheels at all four corners.
    1,718
    Thanks man! Will any 2.2 tire fit any 2.2 wheel? Or do some brands mount different?
    Toronto
    2,143
    2.2 is the diameter, some are wider than others. So you could get a 2" wide 2.2 wheel, with a 1" wide 2.2 tire, and they wouldn't fit. Just make sure the widths are similar enough.
    Then with wheels there is OFFSET, and that is the spot where the wheel bolts to a car, so with more or less offset, the wheel will bolt either closer to the edge of the wheel, or more to the middle of the wheel.
    Then there are the type of wheels, you need ones that are a HEX like the stock one... that's why you certainly don't get 'front' wheels, because for rear-wheel only cars, the front ones are ball-bearing and that's the last thing you want for a drive wheel!
    Hope this helps =)
    1,718
    So will the 2.2 2in wide HPI mesh wheels fit? They say they have a traxxas adaptor. Has everyone put the proline hole shots on a MERV?
    Toronto
    2,143
    Yes those wheels will fit, but I have never used that rubber.
    1,718
    What do you mean? You never used proline tires?
    1,718
    I just ordered some white HPI mesh wheels. Im gonna dye them black! Im gonna hold off on tires till the speed hawgs are back in stock.
    Australia
    66
    I assume the black ones were out of stock?? I think krallopian meant he hasn't used Hole Shots, not proline in general.
    514
    The HPI Mesh are my favorite. They remind me so much of Ford GT wheels.
    1,718
    Quote Originally Posted by Sith Lord View Post
    I got them from towerhobbies. The only ones in stock were white. But dying parts is stupid easy. So im just gonna dye them black or blue.
    I think im gonna keep the wheels till i can get some speed hawgs. And i think ill get some HPI monster ss rims and put the proline hole shots on them for off road.
