This thread just shows the simple mod for putting the rear shock tower in the front of your truck. This way, you can use rear 10th scale of 8th scale front shocks on your truck. I did this mod because I just ordered some Hot Bodies D8 Shocks, 2 sets of 97mm. This mod with let you use these shocks all around without modification.
Start by removing the stock or RPM front shock tower. *New rear shock tower must be plastic*
It won't fit facing foward, you have to rotate it to fit.
To use the sway-bars, dremeling just the sides isn't enough . You can sand through the tops holes, the camber links use the holes underneith them.
Using the rear tower up front causes the body sit too tall. You can modify the stock body posts by cutting them in half. This will make the body sit like it did before. If uneven, you can add spacers of washers.
Stock RPM Modified
You will need to ream two new holes. Unless your body is Jconcepts, which has dotted holes for the SC10, which will fit perfectly.
Hope this helped, let me know if you have any questions.
