Thread: 4x4 Problem
    10
    4x4 Problem
    I took my slash 4x4 out bashing and the next day i went out to drive it and the 4x4 wont work only the rear wheels will spin, i reset my esc and still it wont work please respond with whatever this could be. And yes im sure its not a 2x4
    Lilydale, Victoria, Australia
    2,845
    Pull the rear end off and check the slipper assembly
    Check the bearing in the motor mount and the plastic slipper bearing adapter
    Cheers
    Slash Platinum
    10
    Thanks for your time ill make sure to give some feed back on success or not
    285
    does the center drive shaft spin ???? if so then you have a front end issue... you prob. broke the front drive gear.... i just spun mine right off... plastic... wish they would upgrade it to steel.....
    10
    yes the drive shaft spins, Thanks again for the reply's
    Kansas City, MO
    176
    All of the gears in the front end of my truck are steel. What plastic gear are you referring to? Only Plastic gear is the spur gear on the slipper. If the spur gear is gone you have NO-WHEEL drive
    From parts UNKNOWN
    15
    check your links on the center shaft, its possible the pin may have come out that connects it to the diff. and also check and make sure the pins on the front axles are there too.
    10
    I checked the linking points from the drive shaft to the front end and it was disconnected, re-connected everything and works fine now. Thanks for everyone's help!
