Results 1 to 14 of 14
    Apr 2001
    Queens, NY/Orlando, FL
    488
    Does Robinson Racing make a 26T pinion?
    My 26T CC pinion chewed up a 50T spur after it got loose on the shaft
    The problem is the teeny grub screw the CC pinions have
    It seems I just can't get it tight enough, even using quality drivers
    My 25T RR pinion has a larger grub screw that's pretty solid, so I'd like to get one in 26T, but I don't see it listed
    Houston, TX
    627
    ive never seen a 26t listed either you might try emailing them. i emailed them and they got back to me later the same day
    Feb 2010
    El Sobrante, Ca
    7,543
    I know castle makes a 28.
    Lilydale, Victoria, Australia
    2,845
    Slash Platinum
    Xerun 150 / Tenshock SC401 3500kv
    Dec 2006
    camillus, ny
    2,560
    use loctite on the pinion set screw. even using the rr pinions i had to loctite it.
    Man i need more than 50 characters.
    Apr 2001
    488
    Quote Originally Posted by crusey View Post
    Thanks for the link
    Just ordered one
    Quote Originally Posted by Apexracing View Post
    I change my pinions too often to use Locktite
    Besides, even though the grub screw got loose enough to slide on the shaft, it was still tight enough to strip while taking out
    If I had Locktite on it, I'd probably drilling it out right now lol
    Ohio
    149
    I hate the little grub screws that cc use.....I do like the bigger one that rr use. If i knew b4 i ordered several diff pinions for my new castle motor with 5mm shaft i would have never orderd them pinions....I have almost replaced all the cc ones with the rr...cc pinions are a waste of cash imo.
    Apr 2001
    488
    And of course I have video footage of when it happened lol
    You can hear the motor start singing when it let go
    2,845
    Nice
    Just use some blue loctite, doesnt take any longer when inserting the grub screw
    How does your car open the door for itself
    Cheers
    Slash Platinum
    Ohio
    149
    Nice
    With them cc pinions i almost promise if you used blue loctite you will be drilling that grub screw out....thats even using the good tools....its not a very good quality part.
    Apr 2001
    488
    RC Monster 26T pinion came in a few days ago, but only got a chance to install it today
    Unlike the CC pinion, it has a nice big 2mm grub screw
    Also installed a new 50T spur
    First impressions:
    1) Install was a snap. The larger grub screw made it easier to line up the reducer sleeve on the shaft.
    2) The RCM pinion actually has a wider surface area than the CC pinion, which makes alignment with the spur easier.
    3) The mesh is smooth and like the CC pinion, it's quieter than the RR 25T.
    I ran a pack through it earlier chasing cars and bashing inside my shop and the mesh remained perfect
    Charged it up again and hit the road again, but popped a wheelie on a top end run and went cartwheeling, just narrowly missing me
    Ended up snapping a rear LCA
    Worcester, Massachusetts
    1,396
    snakeeater, what type of 4s do you run?
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    Apr 2001
    488
    Quote Originally Posted by traxxasFTW View Post
    [img]http://www.fuelslut.net/ihost/files/123/*******4spackk.jpg[/img]
    1,396
    Quote Originally Posted by 98 SNAKE EATER View Post
    my friend says to stay away from *******. But i can find this same battery for 25 bucks on a website. Seems that you like, maybe i should pick one up?
