+ Reply to Thread
    179
    Lipo charging help :(
    I just got my lipo charger for my slash 4x4. My 3s lipos arent charger on more then 1.9A? The charger just shuts down and restarts. My 2S 2300mah lipos charge fine. I dont even know much about the charger. Please let me know. Thank you.
    Rotterdam, Netherlands
    6,255
    Use Lipo Balance. Never use Lipo charge.
    Besides that your external power supply probably is not strong enough to feed it.
    Edit: read this first
    Nobody is born with experience.
    179
    Thanks! that solves my problem. These are the specs of my Adapter:
    Specification Input :100-240VAC (50-60Hz) Output: 12Vdc 1.5Amp
    Thanks again.
    6,255
    I have owned the same charger for almost a year. It's not too bad. Dont forget the charger wont get to 5A even when you use the right power supply. It is 50W. Since amps x volts = watts, you would need 63W (12.6 x 5) to charge a 3S battery with 5A.
    179
    That means it would be around 4.5A.
    6,255
    Quote Originally Posted by ControlledWithRemote View Post
    In fact a little less than 4A (4 x 12.6 = 50.4). But most of the time it does a bit more than 50W. If I remember well, mine did around 4.2A.
