Results 1 to 32 of 32
    Arkansas
    522
    True-Track Rear A-Arm Conversion
    Looking for opinions on the RPM Tru-Track A-Arms.......the Good, the Bad and the Ugly????
    kansas
    7,570
    Well the are a good set of arms, sets the two for you. But if I remember they do not work with the LT rockers.....
    Jan 2010
    Wales. Uk
    741
    Mine rock. Very happy with them. Just don't use cvds. They bend way too much. Stockers or summits.
    Signature removed due to excess awesomeness.
    Arkansas
    522
    Thanks guys. I've read that they flex more that the stock arms; which I guess would explain why they dont break as easy as stockers. I've also read on other threads about the CVD issues, which again goes hand-in-hand with them flexing more.
    Thanks for the input.
    Port Alice, BC, Canada
    1,019
    Wait, so I should be using stock shafts rather than the TRX CVD's if I have rpm arms on my ERBE? Very new to this truck, I bought a roller with CVD's all around, rpm arms all around, carriers, etc... So what you are saying it would be wise to use stock CVD's with the RPM arms due to flexing which will result in broken/bent CVD's?
    Haven't got my roller in yet but I can't wait. always wanted a ERBE
    Like I said I am very unexperienced with this truck, I have owned a lot of them besides this one (ERBE). If this is the case with the CVD's and RPM Arms, how would those stock shafts hold up to 6's as I plan on running 6's. I imagine they wont last long as I love to go fast and jump high lol, there must be an alternative. Sorry didn't mean to jack your thread bud
    1/10 Rally x2/P4de/P2de/Rustler/Sl4sh MT
    8
    Stephan all you need to do is get longer drive cups. That should help with the flex. Traxxas has them I just don't know part# off hand.
    1,019
    Ok, I will look into it Thank you!
    Jan 2010
    Wales. Uk
    741
    Longer cups will help with shafts popping out but not with the shaft bending. I bash hard and found that my cvds were bent even after a mild session.
    If you drive carefully then fine but don't expect to be able to push the truck with rpms and cvds.
    I actually got so fed up of having to remove the shaft to straighten it that I ground a groove into a flat head screw driver to smash it straight with a hammer without having to remove it. This is not a fault of the traxxas cvds by the way, they just don't marry up well to rpms.
    1,019
    Wow, good to know. And I don't really like driving aroudn carefully lol, pretty boring. What are you using RevoMikey? What's your setup? You using RPM arms I assume and what do you have for shafts?
    Jan 2010
    Wales. Uk
    741
    I have rpm tru tracks but have just bought summit shafts. Cvds weren't successful, egging was replaced with bending. Stock shafts are ok but egg at the pins way too quickly. Not run the summits yet but the reviews are awesome.
    8
    Ya I didn't say the shafts would last. LOL.. Mine looked like those to mikey.I just by sets of stockers at a time. I have a ebay chop shop down the street that sells them to me for 10 bucks a set. Its always good to have extra parts!!!
    Nov 2008
    Troy Michigan
    1,454
    Quote Originally Posted by revomikey View Post
    Wow what the heck did you run into to get the cvd to bend like that? Iv been running my cvds with rpm arms for awhile with no issues. Im not using true track rpm arms tho. I have bent a cvd in the passed but that was because i ran my truck right into a parked cars tire going pretty fast and even then the cvd didnt bend as much as the one you have.
    ........and did you say you use a screw driver and hammer to straighten out the cvd with out removing it from the truck?!!?!?! man that cant be good for your bearings, hubs, drive cups, diffs and so on.
    E-Revo MMM-2200 6s
    Jan 2010
    Wales. Uk
    741
    Lol. That bend is from big airs. I am not kind to my erbe.
    And as for my bearings, nuts to them, I have a tonne of spares. Tapping the shafts straight has never caused any damage to them, still on the originals. You would be surprised just how light a tap it takes to straighten them, they are pretty flimsy.
    Jul 2010
    441
    i run the losi shafts on the true tracks and havnt bent one yet
    ive bent 2 losi front axles when i hot things side on like park bench or a tree
    but if i crash from jumps and stuf fits ok just solid objects due the damage
    313
    i only bash on Nimhs so far, and i have yet to bend a rear axle. i use the extended cups *on one side. and have never had the other side pop out, ive had a few decent crashes, nothing toooo bad. and havent bent one yet. i bent the front one once, hitting the only pole in the area... duh... lol oops. (my fault)
    i also was doing a bunch of pretty hard jumps with not much of a landing area, it was all ice/pavement. never popped or bent. maybe its all in the tire angle too? maybe if the camber is in a little then it helps? (or out) lol i dunno.
    so far, i love the setup. but if i do bend or break them, im planning on just going to Summit CVDs. i didnt think they were different till someone showed me an actual sidebyside picture. lol
    also, does anyone here flip their axles so the boot is closer to the bulkhead? ive been told this will make the boot last longer. and i can believe this... i look at my driveshafts now and they are shinier near the inside, so it must get less abuse up there.
    i did it to my friends revo 3.3 for a test... lol
    Jul 2007
    Rc Room
    1,509
    I've flipped mine also now the boot lives longer than the shaft.
    USA
    147
    Quote Originally Posted by ClintOnNitro View Post
    ...also, does anyone here flip their axles so the boot is closer to the bulkhead? ive been told this will make the boot last longer. and i can believe this... i look at my driveshafts now and they are shinier near the inside, so it must get less abuse up there...
    Can you explain this for me? I have TRX CVDs and not sure what you're flipping. Thanks
    ERBE, MERV, REVO, E-Maxx
    Springfield, MO
    3,686
    You take the CV apart, and swap the ends, so the axel stub and the diff outputs go to the opposite side as they started.
    that puts the rubber boot up close to the diff, instead of down by the knuckle.
    The rear cv's get blasted by the front tires, so its a good way to protect the rubber boot....
    USA
    147
    Quote Originally Posted by ducati777 View Post
    Thanks for explaining! I'm looking pretty hard at getting the RPM conversion kit. I suppose I could put the rear stock shafts back on if CVD's are not working well with the RPM set up.
    Springfield, MO
    3,686
    I really like the summit CV's. If your CVD's are in good shape you could try selling them on ebay...
    USA
    147
    So the Summit CV's are beefier than E Revo? I'll look into them. I think I'll hold off for now on selling my CVD's and doing the conversion. I'll wait til something breaks. It's hanging together for now. Although my son managed to break the front bulkhead with a ramp he built. It flew well.
    313
    CV joins are stronger than UV joints... just the way it is. metal is stronger than most plastics though... lol but also more $
    1,019
    Anyone have the part # for the longer cups for the TRX CVD's? I have looked around and can't seem to find them.
    313
    Quote Originally Posted by Stephan81 View Post
    5153R - extended cups
    5153 - normal ones
    Jan 2010
    Wales. Uk
    741
    Don't do it. Go summit shafts instead. Even with extended cups you still get pop outs. I got so sick of it.
    I have run stock, cvds and now summits. Summit shafts are the best. Traxxas should fit them as standard in this beast.
    313
    i was out bashing today and did a few HIGH SPEED cartwheels (oops) no bends, or pop outs for me. and ive only got an extended cup on one side. hahaha
    Jan 2010
    Wales. Uk
    741
    Are you running tru tracks though? I bent a shaft and suffered a pop out at least every set of cells. Cvds sure do look sweet though.
    313
    yessir. Truetrack RPMs for the back on my Revo, with Big Joe tires and LT rockers.
    78
    So your using true tracks with LT rockers? I thought they didn't work together?
    313
    thats what im reading, yes. but on my truck, im rocking the long travel rockers, with Traxxas CVDs and i dont even NEED an extended cup on one side. lol i put new bulkheads on when i got the truck cuz it came with summit ones and NO extended cups.
    (yes, summit bulkheads cuz the guy thought they were stronger) they were both also broken. haha im running Traxxas Revo bulkheads now... oh and the shocks are set to the farthest out holes, so its as low as LT rockers can go, that might be one reason why im ok.
    78
    Interesting... I'm guessing the lowest suspension setting must be whats allowing you to use them.
    313
    youre probably right. i could try jacking it up and see what happens i guess. i like the lower stability and still have some travel for jumping over stuff. :P
