    527
    Steel transmission gears problem
    The 2nd speed (17t/29t) gears aren't moving as smoothly as they should. I need to use a decent amount of pressue to make it go around. Will these fix themselves if I run the Jato at a slow speed for a while? After a while of just forcing it by hand, it seems smoother.
    527
    Well Hot Racing is recieving an angry email.
    Check out that fine manufacturing. The metal hasn't been cut down enough.
    RC Turnbuckle Jr. Desert JATO's Avatar
    Aug 2007
    Riyadh, Saudi Arabia
    5,661
    Do you mean that those 2 teeth were separated more that it should ?
    i wish that they'll replace them for you or at least refunding you.
    527
    Photo doesn't really do it justice, but it's meant to be deeper in between the teeth. As a result, the 17t gear won't mesh. I fixed it with my dremel, but it's not 100% perfect. Works though. Sent Hot Racing an email.
    Aug 2007
    5,661
    that's bad to hear it going with you
    next time buy stock gears and adjust the slipper clutch "at least 3/4 turns " out from close. this will save your trany. i'm using an o.s 21tm engine for years now, and i'm still having the stock internal gears... no damages at all. my current setting with this engine is 1 1/2 turns out from full close.
    Oct 2005
    South Florida
    18,503
    Quote Originally Posted by Mind_Reader7 View Post
    I understand the frustration when you go to Hop Up/Modify to improve things.. But his is not a Traxxas product you are asking support for.
    Robin Williams
    He will be greatly missed...
