Changed the diff. Oil and after putting all back together i stripped a wheel and the hex also wore down. Front has all the power and the back does not do much. Checked the slipper clutch and adjusted several times. Still does the same. Front tires tear up the grass and the back wheels are almost dead. Hold the truck on the ground and the back dies not nove but the front spins. Any ideas????
