    Oct 2011
    194
    Will the steel diff output yokes work on the 4x4 pede?
    Its tra 4628x
    Integy Steel Half Shafts
    I was wondering the same thing. I also found that integy has steel halfshafts for front and rear. I was afraid that since this is the parts that seem to break the most for me though, that i would only cause more expensive repairs by allowing the problem to occur either in the diff or worse, the motor! Cant wait to see a reply.
    Okanagan Valley B.C.
    731
    Not sure but if you pick up a set and run a few 3s packs on them I'd like to know how it works out for you.
    O.S.21 Nitro Revo, Stampede 4x4, 2 Axial Honcho's
    Dec 2006
    camillus, ny
    2,560
    Quote Originally Posted by Ige_santos View Post
    Its tra 4628x
    you would probably be more prone to breaking the driveshaft instead with just adding the yokes.
    Man i need more than 50 characters.
    El Sobrante, Ca
    7,681
    They will work. I had some on for awhile. They made the shafts last longer. I suggest going to Mip X-Duty shafts. Put them on and forget them. I have had mine for over a year and have had absolutely no problems with them.
    Nov 2011
    Portland OR
    381
    I got those but they aren't the correct width for the plastic driveline yoke on a 4x4 stampede. Found correct plastic shafts at hobby shop, quickly destroyed all 4 of them on 3s. slipper was 1/2 turn out. wasn't driving like a maniac.
    Oct 2011
    194
    Thanks for the input. I have mips on the rear and stock shafts on the front. Just want to make the yoke stronger than stock because thats where i break it most often.
    El Sobrante, Ca
    7,681
    Save up for X-Duty's on the front
    Oct 2011
    194
    Will teknos be good in the front? Im using rpm arms. Are there any rubbing issues with the teknos?
