Results 1 to 18 of 18
    Raeford N.C
    107
    Lowering The ERBE
    Which parts have to be adjusted to lower the ERBE.I plan on running mine on the street only.
    kansas
    7,895
    Push rods put them in the out hole, it will lower the ride hight...
    5318
    May 2010
    Silver Spring, MD
    216
    Put the push rods in the outer hole
    Raeford N.C
    107
    Thanks.Im still new at this.Replacing the bulkhead today was kinda out of league.I watched the guy at the lhs do it.It was like a nightmare to him.It was like a nightmare to my wallet having to fork out $30. for him to do it.Haha.
    144
    lowered mine already like gn said to the outer holes
    mine just for the street too no jumps and bashing just wheelies
    Raeford N.C
    107
    I hear that.Ill break out the T-max for the jumps and offroading.Its bad enough I broke a bulkhead and didnt even realize I hit a mailbox post that hard to do that kind of damage.
    Raeford N.C
    107
    I cant seem to lower the body shell all the way down.The wing mount is in the way.How does everyone fix that one?Cut part of the plastic off th body shell?
    May 2009
    Edmonton, Alberta
    3,604
    yep, just need to cut a hole out at the back to clear the wing mount.
    144
    even on the street you have to be careful with the curbs and stuff
    Long Beach, California
    6,727
    if your still not satisfied of how low it is... you can take off the pushrod spacer (red/blue)
    | Rally GT8 Powered By CC | 360mm XO-1 GT |
    5
    I would suggest doing most if not all of your maintenance & mods yourself. Reason why, it's less expensive and in the end its rewarding knowing you did it yourself. Whereas I don't have ANY experience w/ E-revos, I do have experience with maintenance, rebuilding and building of nitro models such as the Jato & revo, plus w/ the forums here it makes doing it yourself much easier & feasible.
    "We FIGHT as a single impenetrable UNIT"
    Puerto Rico
    178
    The best way to lowering the E Revo is using zip ties around the body mounts and suspension
    -EA DIABLOOOO ! ESO ES DE GASOLINA, VERDAD?!?
    Raeford N.C
    107
    Thanks for all the good tips yall.Im gonna try the zip ties option.I am worried about cutting on the bodyshell though,it may split.Is their anything good to put around the area I cut to avoid it tearing?
    899
    Lowering The ERBE
    No ones mentioned decreasing the shock preload. I thoughtd thatd be the quickest way to lower the ride height
    May 2009
    Edmonton, Alberta
    3,604
    i you are running exclusively street, i would also recommend using some limiters in the shocks. Takes the downward travel out of the equation and slams the rig down to the ground.
    You can get it pretty darn low... im actually thinking of raising the front a tad by removing one of the spacers up front, now that i have the big bumper installed.
    As it is, this is my ERBE-gt i have 13mm of limiting in the shocks and it is super low.
    Front ride height
    Rear height
    Granted this is on slayer arms, so the drop may or may not be the same on Revo arms, im far from a math guy to figure out that geometry haha.
    203
    What gains do you get from using slayer arms? Also what tires are you running?
    Sent from my DROID RAZR using Tapatalk
    May 2009
    Edmonton, Alberta
    3,604
    check out my thread, i was just mentioning shock limiting as a method to lower the car.
    http://traxxas.com/forums/showthread...uild-continued.
    im using slayer arms for a reason
    203
    Cool im gonna ckeck your thread out
