    Fulton, Ms
    26
    Stripped Pinion Screw
    Anyone know if there is a ezout small enough to get out the pinion screw.
    St. Louis
    379
    i had to dremel a slit in the set screw and use a small flat head to get mine out one time. wont be able to use that pinion anymore though
    Racing in the Past, Present, and Future...MAYBE
    El Sobrante, Ca
    7,597
    My tool set has a driver that is slightly bigger than the one used. I can usually get it out with that.
    Clearwater, FL
    60
    Just had that happen to my 22 pinion gear yesterday. I used a dremel to cut right into the pinion and used a small flathead. Be careful as due to the size of the screw, mine ended up splitting when I tried to turn it. Ended up dremeling more into it but be careful not to cut into your shaft, finally pulled on it to get it out. Was worried for a moment that I was stuck running 22/50 gearing
    El Sobrante, Ca
    7,597
    You can slide them off by prying with a screwdriver. You wouldn't be stuck. Sometimes I just pry them off, then remove the screw if it is stripped.
    Clearwater, FL
    60
    This would not bend the shaft? I wanted to do this yesterday but was afraid of bending the shaft so I went the dremel route.
    El Sobrante, Ca
    7,597
    I have done it many times without ever bending the shaft.
