+ Reply to Thread
Thread: Help please!!
    60
    Help please!!
    hello, i just got into indoor racing and i want to know how do you lower the shocks?
    thanks for help!
    MERV, SLASH 2WD BRUSHED, CRAWLER
    RIP REVO 3.3
    60
    besides changing the position I know it has to do with the shock shaft itself I'm just unsure on how to do it......
    RIP REVO 3.3
    194
    You did mean to lower the ride height right? Put tubing or spacers inside the shock under the piston. Keeps them from fully expanding. Also move the mount positions to the outside most holes.
    But what type of indoor racing? If off-road, you'll need some compressibility for the jumps.
    Go to this website: http://www.rcarindy.com/classes.html
    Click on the pictures at the top right. The third one is what you want to look at. I used pastic spacers instead of tubing. But same result.
    You'll have to unscrew the shock ends with the pivot ball. When you do this, you'll have to hold the shock shaft with pliers. Do NOT scratch the shaft. If you do, those scratches will wear out the o-rings as they pass through them. I always hold the shaft at the very bottom just above the end. This part of the shaft is least likely to pass through the o-rings.
    Just remember, you may have to fiddle with the amount to get the ride height you desire. Put them together without oil or the diaphragm and install on the truck to check height.
    BTW, after you jack up the ride height, you'll have to reset your camber and possibly tow.
    Also, since you're in there, now's a good time to change the oil weight. I use 50/60 for off-road and 80 wt for oval.
    60
    ok cool thanks yeah I meant ride height.Indoor racing on carpet no bumps just an oval.I have the spacers that came with the slash,so I will use them................Should I do all 4 or just the front, this is all new to me....
    RIP REVO 3.3
    Jan 2008
    South Jersey
    7,788
    You want to use these:
    http://www.amainhobbies.com/product_...ter-Set-TLR-22
    Lots of different sizes and way more accurate and consistent than fuel tubing.
    194
    I have mine down to 1/2" front and back.
    60
    Quote Originally Posted by harry697 View Post
    Good deal how many did you put on each shaft?Guess i'll be placing an order today..........
    RIP REVO 3.3
    Silverdale, WA
    1,935
    Fuel tubing works, but it has a tendency to split in the shock messing up your ballance. Those spacers take a lot of the guess-work out of it.
    Submarine Qualified, Chief Inducted, Navy Proud
