Thread: Which 4S LiPo?
    Sep 2011
    5
    Which 4S LiPo?
    Presently I have a Venom 3S1p LiPo battery (11.1v, 5000mah, 35c) in my Slash 4x4, but would like to try a 4S. What voltage, mah, and cont. dist. number should I be shopping for in a 4S?
    Already have the correct CC ECU/motor combo to handle it.
    Lilydale, Victoria, Australia
    2,845
    5000mah 40c
    Cheers
    Slash Platinum
    El Sobrante, Ca
    7,084
    I have a Venom 4s 5000mah 35c lipo and love it!
    Sep 2011
    5
    I found two Venom LiPos one has a 35c, and the other is 50c burst rate. Any up or down sides to either of these two? Doesn't the burst rate affect the initial "punch" when you pull the trigger?
    Tampa, Florida
    174
    I have had a lot of luck with the venom lipo's in both 2 and 3 cell in all of my rigs.
    Went to get the 4s hard case and even with the larger battery adaptor it wouldn't securely fit.
    Not to jack the thread but has anyone else had similar issues?
    I have heard of cutting slits in the chassis with a dremmel and running velcro thru. Does this work?
    If so what Velcro staps do you use and are there any problems that arise from this?
    Slash 4x4
    MMM 2650
    Rustler VXL
    Emaxx
    Apr 2001
    Queens, NY/Orlando, FL
    488
    Quote Originally Posted by magfli View Post
    I have a GoPro mount that my hard case 4S pack just barely squeezes under and it's pretty secure with that , but I also use a pair of velcro straps from T.A. and they work great because the loops are angled 90* to fit the edge of the pack
    El Sobrante, Ca
    7,084
    The extended battery clip does fit. You have to turn it to the side where the clip goes up. It fits nicely.
    Apr 2001
    488
    Worked fine for my 3S until I installed the GoPro mount
    Traxxas should make note that the two are not compatible
    Some pix of my T.A. straps
    15,149
    I just tape a couple of my SPC 2S hardcase packs together and use a series connector for 4S. They fit fine with the battery expander. This way I can use the 2S packs in my other vehicles.
    Alt-241 on the number pad =
