+ Reply to Thread
    Detroit area
    61
    Do I need to exhaust new battery on first run?
    New to the hobby and upgraded my Raptor battery to a Speedpack Ni-MH 4500 mah.
    Just wondering if I'm supposed to run it till empty? Or is it ok to stop halfway and recharge for next time?
    Thanks in advance!
    Mar 2009
    Jacksonville, Il
    527
    Either way is just fine. I would run it down every so often though. I don't mean let it trickle discharge on small lightbulbs either. Just run it in ur truck till you notice it dump.
    Lock, Stomp, and Steer. No Fear
    Detroit area
    61
    Cool.
    Thanx
    Jul 2009
    Ontario, Canada
    11,065
    You should NEVER run any battery to full flat... that is bad for any pack, lipo, nimh or nicd... most people think you should run them right flat but this is never the case.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Nov 2011
    952
    Agree with Pav above, when the vehicle slows down it is the LVD kicking in, running it down further can put the cells below the minimum too far, not good for the batteries and sometimes your charger will not pick up on the charge cycle as it detects a 'low voltage' safety issue.
    Jul 2009
    Ontario, Canada
    11,065
    For lipos yes... but for NIMH's there is no LVD so you need to pay attention to when the truck really starts to loose power. Your going to notice a drop in performance after about the first 5-10 minutes. Thats typical of a NIMH pack. But after youve run for a while your going to notice another big drop in performance. This is when you should stop. Most kids just keep running till the truck won't move... this does irreversible damage to the cells.
    In this regard, lipos are actually easier because the Low Voltage system (whatever system your using) will tell you when to quit. With nimhs you gotta know when.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
