Results 1 to 39 of 39
Thread: Dewalt upgrade.
    32
    Dewalt upgrade.
    I thinking about upgrade my titan 775 to dewalt 14.4v.
    I have the old 27mhz radio, it can run good with it? or should I buy 2.4ghz?
    What else do I need to buy for this upgrade?
    Sent from my Nexus One using Tapatalk
    Apr 2010
    Northern Michigan
    839
    Just make sure that you use capacitors on the motor and you should be fine.
    142
    With all due respect, UrielZ, there are about 20 threads about the DeWalt. All questions have been answered a hundred times on the DeWalt. Why don't you look around a bit in the forum? Thats why we answer questions, for others to benefit.
    32
    MJP, I've been searching about my questions and I didn't find a final answer...
    11,065
    http://traxxas.com/forums/showthread....-LOTS-OF-PICS
    Heres mine... good info here too.
    If your using the AM radio the caps are a MUST have. If your using a 2.4 you don't HAVE to use caps. I don't and have no issues. The only other things you NEED are soldering supplies, a drill and a dremel... all is explained in the above posts and mine.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    KC
    310
    This probably should have been the first response to the OP's question.
    +1 Jimmie Neutron!!!
    11,065
    Quote Originally Posted by MJP View Post
    I don't think this was really necessary... he's only got a few posts and is clearly very new here. There are nicer ways to suggest a person search around a bit than this. Not to mention, he is asking a question (the caps) that isnt very clearly answered in most dewalt install threads. Many show you HOW to do it... but not let you know if its NECESSARY.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Victoria B.C Canada
    4,280
    Good work Jimmie....now if he had said "I'm too lazy to search" then jump on him otherwise ,that what these forums are for....right
    Mountains cant stop me
    they have tried
    142
    I apologize, I just had the impression that we go into the 120th thread on DeWalt here and when I did my DeWalt conversion I was so confused by these many threads that I wish that we close 110 of them and keep those 10 threads that contain all knowledge about the DeWalt.
    Google Search for "dewalt traxxas caps" will bring this up:
    "At 2.4GHz the interference created by the motor is far less than at 27MHz or 75MHz, but not knowing exactly how much interference is generated at 2.4GHz (no experience with a cap-less brushed motor & 2.4), there could possibly still be a small reduction in range if you run it without the caps."
    55
    I wish somebody would just sell the motors ready to bolt up! I can't solder for crap nor do I have the tools.
    13,469
    Quote Originally Posted by Gizmo1988 View Post
    Kershaw Designs offers this service (for a fee) on many of the brushed motors they sell, including the Dewalts.
    It would be better to learn how to solder, but to each his own.
    883
    Dan from kershaw designs does. I bet he makes quite the profit too
    13,469
    Much better than the "Do a search" post above. Bravo.
    @ varunaX: Beat ya!
    Victoria B.C Canada
    4,280
    I ran am for a while when a cap breaks I knew right away.glitchy glicherson. 2.4 no issues
    they have tried
    32
    Thank you all for your help!
    I think I'll go with the kershaw option....
    What pinion/spur should I need for a 30mph top speed and cool motor?
    21
    I could never find a happy median for my gearing. my motor ALWAYS ran hot. I had tried everything from a 11 to 14. BTW i was running RC4WD mudslingers with every other lug cut. I recently put in a rx8 with a 1700kv truggy motor and LOVE it.
    Rob
    32
    in the kershaw designs site i can choose different pinion: 17,19,21,25.
    which pinion should i choose if i'll buy the Integy Heat Sink Fan with the motor?
    u.k.
    1,430
    depends where you drive,
    muddy off road go lower, 100% of time
    Mostly off road but some on road go bit higher, 60%off road/40% on road
    On road with some dry off road go higher,60% on road/40% off road
    On road go higher.100% on road
    if your stuck go with a middle of the range size change some spurs as they are cheaper.
    there is no right size or wrong size, check the temps of the motor and change accordingly.
    It's trial and error, as i would imagine people try to run on the same sort of terrain most of the time.
    i try to stick to wet grass sometimes muddy might be in different places but thats what i look for, but mines in a maxx,
    Motorcycle/Quad,Think sand vehicle, piggy backs
    11,065
    If you want 30mph you may be better off with the dewalt motor. The Kershaw 700HO motor (which is what I assume your thinking of) isnt alot different than the titan 775... id start with stock gearing and keep an eye on temps. But your not going to get 30mph without heat issues unless you go dewalt or brushless.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    32
    pavmentsurfer, i think you didn't understand me. kershaw design makes moded dewalt for the summit. and that's what i want, not the 700ho. and in their site the dewalt comes with few pinion to choose: 17,19,21 and 25. therefore i i'm asking what pinion should i go with for more speed & torque as the titan...
    11,065
    Ahhh, so you can buy a ready to instal dewalt motor. That's cool. What do they sell it for?
    I would think since stock is 14/68 you could get away with a 16/62 combo. I know you can do 16/68 all day with. I he's issues, and I think I've heard a few people even running 18/68.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    32
    alright, so now the decision is between the 17t to the 19t- they don't offering 18t.
    BTW sorry for bothering, i'm new to the summit and haven't touched the hole gearing thing yet...
    107
    Kershaws dewalt is about $35 + $8 to prep for am/fm and $4 to prep for 2.5 ghz A pretty sweet deal if you hate soldering the wires and caps on.
    21
    Not only that but the dewalts are difficult to solder to cause of the limited space.
    If i were to do it again i would pay him in a heart beat to solder it up all good.
    Rob
    883
    Why is the summit so mmuch different than the erevo? He offers a 31t pinion for the erevo!
    I thought the chassis and parts are all identical , other than the locking diff
    13,469
    Got no business running a 31T pinion in a Summit.
    kansas
    6,306
    Quote Originally Posted by UrielZ View Post
    Quote Originally Posted by magnashopper View Post
    Quote Originally Posted by Rxracer View Post
    Rob
    http://traxxas.com/forums/showthread...635-Sum-Summit
    21
    I donno why u quoted me in it. i have already done a dewalt and even kept the dual leads to it. i was just saying i wouldnt really want to do it again.
    i have moved on to brushless anyways.
    if you want pics of the dual wires soldered i can provide pics.
    Rob
    kansas
    6,306
    Why do you say there is limited space??
    21
    If you do the dual wires on the brush area your limited on how high it can go to fit under when you shove the brush into the can. i did dual wires like the stock motor and it was more difficult than doing it with one wire. as i said if u need pics i can supply them.
    32
    In their site i see the motor price is $70, it's because the shiping (i live in israel)?
    so what pinion should i get? consider i'll take the heat sink fan they offer with it
    13,469
    Rob
    Pics are almost never a bad thing. If you have them on a host, put them in a post.
    11,065
    Your a poet... and you don't know-it!
    I would suggest order BOTH the 17 AND 19t pinions. We can't say exactly what will work. If you can ONLY pick one I would default to the smaller one to be safe. But for the extra few $$'s get them both so you have options. Options are always good.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    kansas
    6,306
    all good... if you can post pic I would like to see, how you did the two wires. Might see something new... I am sure it was hard doing two wires, that is why I did one 10 ga wire...
    u.k.
    1,430
    i done the two wires, it is tight and doesn't look good.Used the connector that was on the motor,( I took my motor straight from a drill. The wire that is used is surprisingly small diameter), crimped and soldered. Then spliced off from that near the connector for the other wire and heat shrink around as it's could easily hit the can when moving about.
    I will be changing to a single wire once i get replacement connectors for where the stock traxxas ones are.
    55
    If you just have to wires instead of 4 on the motor what do ya do with the other 2 from the esc?
    13,469
    Combine them in a 5.5, 6.0, or 6.5mm female bullet connector? Use one heavy gauge wire and the male bullet for the motor.
    u.k.
    1,430
    still use the 4 just there joined together, one on the connector and one a little way up the wire, heatshrinked incase it touches the motor casing. Thanks ksb i wasn't sure if i needed 8mm or 6mm.
