+ Reply to Thread
Thread: dynamite Lipo's
    Raeford N.C
    107
    dynamite Lipo's
    I got some dynamite speedpack 5200mah 7.2v 2s 50c batterys.Anyone ever trid them?What kind of top speeds can I expect with stock gearing with these?
    kansas
    6,403
    Middle to high 30's, do you have the 54 spur? That should get it into the 40's easy...
    Raeford N.C
    107
    My ERBE is in the mail on the way too me.Does it come with an extra spur?Man high 30's aint much at all.I figured snce it had a mid C rating I would get up to at least 40,cause man........,the bats were $100 a piece.
    kansas
    6,403
    you paid.....gulp..
    yes it comes with a 54 spur, & go buy a 21 pinion & you are low 50 mph.. just watch your temps.
    change the last two ## in the p/n for the tooth count...
    Part Number: RRP8721
    Manufacturer: Robinson Racing
    Hardened .8 mod 21T Pinion Gear with 5mm Bore (32 pitch)
    (mah x c rating / 1000 = amps),
    The more amps the better / minimun of 120 amps.
    The ESC will only draw the amount of amps it needs.
    Higher the mAh the longer the runtime.
    For brushless systems 8000 mAh about 45 min & a 5000 mAh about 30 min.
    Times are longer for brushed systems.
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F maximum, ideally 140/160*F, temps can be 10* higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F
    Lipo's ~ 140*F max, ideally 100/120*F
    Raeford N.C
    107
    Thats a little relief.......thank God.I found a lhs opened on sunday.I hope they carry that spur in stock.I can deal with low 50's for top speed.Thanks!!!!!
    Raeford N.C
    107
    whoops.I meant to say pinion.So the pinion is all I need and Im set right?
    kansas
    6,403
    Nope if you don't have Castle Link you really need it to set the LVC 3.4v per cell..
    & a few other programs if you want to change punch control..etc....
    http://traxxas.com/forums/showthread...stleLink-Guide
    Raeford N.C
    107
    Well its a good thing I ordered the castle link when I ordered my ERBE.Being that I did and if I do what you say is needed to be done I should be set I hope.
