Page 1 of 3 123 LastLast
Results 1 to 40 of 86
    greenwood cemetery bashplex 8))
    12,369
    My Late Model lcg mid engine build
    Well the guys at my local track started racing 1/8 late model bodies on sc trucks. Being an oval enthusiast, and seeing 2 guys battle it out door to door for 50+ laps and ending 2 seconds apart, I was hooked.
    In the parking lot of the the track that night, I ordered a Slice A-3 chassis from Chuckworks Rc off of ebay for $80 shipped. I went with this because my track is a small carpet oval (70'x35'), and the mid engine setup will help the truck rotate around the super tight turns. This will also help on the off road course they setup on Fri nights as it is mostly super tight and technical. This is also a review of the Slice chassis.
    The SLICE A-3 CHASSIS
    First off, if you do not own a Dremel, and a drill, and do not have the ability to "massage" a few parts to fit, then this chassis is not recommended. At least on my sample. I had to custom fit a couple of parts, and they were pretty far off. Was not a deal breaker for me as most of the parts were just right, but someone that wants parts to fit perfect and everything to go together like Lego's, may incur a big hurdle or 2. I had to read between the lines a bit on the instructions also, they were adequate.
    Notes on assembly
    On the first step, you are to install the three chassis blocks. When I bolted them in, it seemed as though the counter sinks on the bottom of the chassis were drilled too deep, and the aluminum chassis blocks were very loose, even know the 4mm counter sunk screws were bottomed out, through the chassis, against the blocks. At that moment, I thought I was going to have to send it back. I asked another member who has this setup how his was, and he told me to let everything loose till the end. Don't worry as this is a part of the design, and permeates the rest of the conversion.
    When you get all the parts together, you can crank everything down tight, and end up with a solid platform.
    Your gonna have to drill holes in the back of the suspension arms to attach the shocks 2. There is no template included, so your on your own to figure out where to drill them. I used a simple plastic caliper to measure everything.
    The plastic tube that went between the aluminum rear bumper mounts was way to big, I dremeled it down over a inch to fit between the alum rear bumper blocks.
    One other thing is the "battery gate" as its referred to in the instructions is one of the chassis supports, bolted to the "gate". You have to remove the cap head screw from the top of the "gate" to remove the support (what I call the "battery blocker tube") to get the pack in and out. There is no mention on how to do this in the instructions.
    Using an aftermarket trans:
    I installed a new Hot racing full alum trans, but it is a flat motor plate setup, as opposed to the stock gearbox cradle. I had to add braces (the 2.5 Maxx links in the pics later) to reduce chassis flex in the right rear of the chassis.
    Anti squat
    The anti squat plate included with the slice kit,after assembly puts it at 0. This is less than the 1.5 of stock. If you have an FLM or Hot Racing gearbox, you can properly adjust this back to stock. Using a stock trans or other trans you cannot.
    If I forgot anything, I will post it later.
    Anyway, this is what I finished with:
    Being this is predominantly an oval car, I wanted to go with the 4pole castle mmp combo for higher rpm:
    I wanted to switch back to the fine tuning possibilities of 48p gears for the track, as opposed to my 32p bashing setups. The strc top shaft/ Associated clutch setup works like a dream. Much finer adjustment than the stock slipper:
    I have the pro trac suspension, and big bores as well at the ft HR sway bar installed. The links were stock trx links I had laying around:
    In the pic above you can see the rear bumper and shock mount set up. This is the stiffest and most solid tower mount I have seen on any of the magnum trans 2wd vehicles.
    The front top plate is super solid:
    I used a slash 4x4 bell crank, modified to get stock 2wd geometry. I seen it over at URC to get the idea, but cannot find the link right now.
    The Slice came with a threaded rod for the servo link, but I just used a slash 4x4 link. Its the perfect size:
    Whats in my wallet?
    I cant afford a wallet...
    12,369
    Here is a pic of the way I mounted the maxx links to the rear tower:
    I used RC Solutions xtra wide c-blocks in front to give a few more mm widening in the front.
    Overall, I am happy with the chassis so far. Let you know Mon how well it works the first day...
    Whats in my wallet?
    North Central OH
    1,048
    That looks impressive, man I like that engine forward set up! Nice and detailed work on your part. That trans looks cool, what diff set up are you going to run in it?
    Might want to insulate the antenna lead as it passes under the chassis rail just in case.
    How does the balance feel to you?? What are those blue things on the trans case, heat sinks???
    Sweet
    12,369
    Open diff so far, as the track is so tight. The chassis edges are rounded, and the antenna wire is not tight so I think it will be fine. I will not get to drive it til Sun on the oval. Dont have a LM body yet, o I will run it in mod sc, sand yes those are heat sinks.
    Whats in my wallet?
    May 2009
    96
    Nice. Can't you run the battery mounted on the side of the chassis? I saw it mounted that way in one of the pics on the ebay listing for the chassis (of course it looks like it sold now). Get that moved and it should be a purebred left turning machine.
    Indiana
    244
    is the new slipper really that much better?
    - Joe
    Slampede VXL 2WD - Rpm, GH Tranny
    2,215
    That truck is AWESOME!! Love it! So cool!
    Springfield, MO
    3,686
    Looks great, but reaching that point where its hard to call it a Slash!
    I was going to say something about anti-squat, since I remember that being an issue a while back with these mid motor builds, but I guess this chasis figured that out. Its a thin shim under the transmission I guess? Wonder if you couldn't shim it further to get back to stock.
    12,369
    Quote Originally Posted by bgredjeep View Post
    I seen that too. There is plenty of room on the left side, just have no way to mount it there yet.
    Quote Originally Posted by Slick_Whip View Post
    It is more consistent. It holds its setting better than the stock one, and the threads on the strc top gear are finer to give you a better, more minute range of adjustment. The spur gear is a disk instead of a bowl, and does not distort. I would not use it on 3s, because when I tested it on 2s in my MT, with a loose setting, it got HOT quickly.
    Quote Originally Posted by ducati777 View Post
    I was going to say something about anti-squat, since I remember that being an issue a while back with these mid motor builds, but I guess this chasis figured that out.aking e Its a thin shim under the transmission I guess? Wonder if you couldn't shim it further to get back to stock.
    Not much original parts left thats for sure, but I am going up against good racers with race trucks so...
    With that trans I can just just switch the rear arm mounts from side to side to get the squat back, but forgot to do it during the build. Gonna try the truck as is then start tweaking.
    Whats in my wallet?
    Springfield, MO
    3,686
    I keep just staring at the pics.... so much to look at on this truck....
    May 2009
    96
    It looked like you could use the included battery mounts to hold it on the left side from the pic I saw. Check the eBay listing for the slice b2 chassis to see the pic I mentioned.
    delaware
    937
    wow this is a great looking slash do you have any pics with a body on
    12,369
    Yeah it looks a little cluttered to me. I used that center brace to take up the slack on both the servo and esc. Need to clean that up, but I like that I can just unwind the esc wire for the castle link.
    Those braces are not doing much with the rt rear chassis flex, but I have an idea that I will try next week. The chassis plate is 2mm, while all the other fiberglass is 3mm. With a stock trans "cradle" that flex will be gone. I will run it without the braces in the morning. I also have a lot of setup to work out and the track just changed Sunday hours. I get a hour less before the qualifiers start for tuning. My goals tomorrow:
    #1, dont break it!
    2, get it around the track.
    3, dont overheat the motor.
    I am running in mod sc(my late model body just got ordered from "stalkerrc.com")
    Will post pics of that sc body mounted after the race when I get a chance.
    Whats in my wallet?
    12,369
    Oh, and if I go to a left side battery mount, I will use a battery box and eliminate all of the battery posts and braces.
    EDIT:
    I forgot the pic of the bottom:
    Whats in my wallet?
    12,369
    I am very, very happy how everything went, surpassed all goals, qualified and placed 3rd in the A behind 2 sc10's. I forgot my pinions, and was undergeared (both the tires and 4600kv were 95 after the main!) I know I could have got second with taller gearing.
    I also got my late model body for $20 off a guy at the track!!!!!!!! So So Happy!
    The Slice A-3 ROCKS on a smooth, small track.
    I will get pics up of the lm body as soon as I can.
    YAAAYYY!
    EDIT: My driving was the low point of the day, and ironically that was a good thing...
    Whats in my wallet?
    12,369
    Here are some pics of the lm body I picked up:
    These are the original owners pics.
    Whats in my wallet?
    South of St Louis
    5,796
    Have you posted pics of this track before?
    12,369
    yes, Its PT Raceway near Pittsburgh.
    Whats in my wallet?
    12,369
    Got the body mounted for its first Late Model outing. I am going to eventually paint up a Taxi body(with my cab number), but this one was avail cheap($20):
    I have been watching these run for a month and am so fired up to get out and run a "real" oval class...
    Whats in my wallet?
    North Central OH
    1,048
    Congrats man that sounds like fun!
    That body is cool looking, those were some fancy wheels the original owner had!
    Nice to hear the hardware held up and you finished third but had room to gear up and go next time out. How many cars run at once?
    Sweeeet! And wow on the chassis, finished product is one to be proud of for sure
    12,369
    should be 6-8 this week
    Whats in my wallet?
    12,369
    Nope not 6-8, 3...
    Many people went to the motorama race this w/e. Good news though, after a 2 tooth taller pinion, some suspension tuning and castle link fiddling, gained 6 laps on my best run today compared to last week with a lighter sc body. I am about .15 sec/lap off of the fast guy in this class. Led the first 38 laps of the main after the other 2 guys tangled in the first turn, but then he ran me down. He asked me after the 2nd qualifier "are you sure thats a slash???"
    Next up, moving the battery to the left side of the chassis, and a proper set of tires. I want to try a set of proline caliber m2's on slash ft offset. Thats what top dog runs(on sc10 offset) on his sc10 in both late model and sct. I am running bald suburbs m3's on protrack rims, and they are gonna wear through to the foams any moment. He is running a Tekin 8.5, and it seems my 4600 is right there with him. I am a little slower leaving the turns, but I think that is just tires.
    I ran the s1 platinum baldies, but the suburb baldies were better.
    Very happy with the chassis. There is room for improvement, and it is getting there already.
    Whats in my wallet?
    12,369
    6-8 next week... Not sure what I'm gonna do as I cant afford a full set of tires.
    Whats in my wallet?
    North Central OH
    1,048
    I would love to see you and this this Slash-Slice run rag6!
    I am studying the pics and since so much is new to me I am a little visually confused>>>
    pic#3 and #4 show a stamped 'L' and 'R' on the trans mount but they are reversed from what they should be??? Or is this intentional?
    Is the differential accessible easier with this trans set up? The entire trans and motor mounting has me disoriented
    Dec 2009
    348
    Nice build!
    We run SC latemodels on dirt ovals. Looking to start up some parking lot oval races this year.
    I'm an oval fanatic as well!
    12,369
    It takes more to remove and service this setup compared to stock.
    When turning the trans around for this chassis, the rear arm mounts are reversed, which changes the stock 1.5 anti squat to 1.5 posi squat, which is not beneficial to handling. The maker of the slice chassis, recognized this problem during the first version he produced around 2 years ago, when members of this forum(including me) and other forums brought up the point. This current version includes an "anti squat" plate. It should have been called a "zero squat plate" as it levels the the suspension mounts and provides a level 0 squat angle when the stock trans [or HR(or other adjustable squat gearbox such as flm is used in the stock configuration)] is mounted to this particular chassis.
    Now, the HR full aluminum chassis (not to be confused with the $28 HR alum/composite trans, which does not let you switch the rear arm mounts from side to side) has the option of switching the rear suspension arm mounts from side to side (they mount to the gearbox from inside, through the side of the gearbox) to counteract the "posi squat". Everything would be just fine with switching the mounts on the HR, but when using the "anti squat plate" provided, the HR trans would give you 3 of anti squat. Not good. SO! You say, Take the "anti squat plate" out.
    EEERRRRRRZZZZT! Next contestant!
    The way that the motor plate of all transmissions will mount midship to the chassis "box" will leave the trans hovering 2mm in the air, above the chassis if you take out that plate! Not good in the most flexible area of the slice chasssi. Zero squat with this setup I am running has left me with a responsive vehicle and am happy with the "squat" characteristics (not noticing any rear end drop under full brake to full throttle transitions).
    Sorry if that was confusing, but you asked, and that was the best I could explain the situation I have been dealing with, (and hopefully overcome) in these past few weeks.
    PHEW...
    Whats in my wallet?
    Feb 2010
    El Sobrante, Ca
    7,073
    That is a great looking truck!!!
    North Central OH
    1,048
    rag6 replied....Sorry if that was confusing, but you asked, and that was the best I could explain the situation I have been dealing with, (and hopefully overcome) in these past few weeks.
    I think I best stay a bit more basic for now.....I'll see what I can do with the Anza chassis for a bit more simplicity though I have a feeling that I will likely want to build up one of these someday.
    Thanks for your explanation of the squat/arms/reversing/trans debocle LOL
    SLC, Utah
    3,432
    Rag, That is REALLLY nice. Great build bro. Looks way sick for sure.. Very nice.
    12,369
    Got some more pics
    Sc body mounted:
    Lm body mounted:
    Its nice, take one body off put the other on, and I can run 2 classes.
    Hacked the ft bumper to fit:
    The bumper rides in the foam blocks and makes the front super solid. A battering ram basically.
    LTOHHH
    ^^^ I had to drill 1 hole in the chassis, 1 hole in the slash battery hold down. 2 of the slice pieces relocated, and stick on 2 foam blocks. It literally took me 5 mins to convert to lto from the moment I sat down at the table. Just as easy to move back for the off road coarse.
    Whats in my wallet?
    11,146
    GREAT looking truck Rag. So far it sounds like its been holding up for you, but overall what do you think of the durability of this chassis? You mentioned it was more complex to work on, to what level is it more difficult? Alot or just a little?
    Sounds like it was an impressive rig as an SC truck. Did it jump more flat than a rear engine SC truck? More balanced?
    Awesome job, looks like no expense spared... just the way we like it right.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    12,369
    Durability so far is very good. The jumps at my track are small, so its hard to tell the way its gonna fly big. It is very balanced. The first traxxas 2wd I ever had to reduce the steering lol. So much steering...
    Whats in my wallet?
    12,369
    The next challange
    Ok, after a couple more Sundays of oval, I want to try this chassis on the off road course on Fridays. Here is a vid of the mod sc a-main last night:
    http://www.youtube.com/watch?v=eY68c...ature=youtu.be
    The guy blowing away the other trucks from start to finish with the Kyosho made the a-main at motorama 2 weeks ago. He never wrecks lol. That is my goal, and I am probably in for a big let down, but gonna set my hopes high. My first love is oval, but as you can see in the vid the track is very tight. The dna of this chassis should be just right for the tightness, and I want to see what it can do. I would like to find a way to be able to switch easily between LTO and off road configurations also.
    Whats in my wallet?
    Jan 2008
    South Jersey
    8,141
    Wow, that is one tight track!!!!
    BTW, been watching this thread and wanted to say very nice job on the build! I've seen a few build threads with these Slice chassis' and I gotta say yours is the most impressive. Nice to see you took the time to address the little issues. I've seen too many builds that have something obviously wrong with them, but yours looks right. It's worth taking the time to do the little things to make it correct. Great job and good luck keeping up with that Kyosho! That guy looks like he's on rails!
    12,369
    If you aint first, your behind Matt Stoltz... I dont get to the track very often on Fri nights, but the 4 or 5 times I have been there, Ive only seen him have to be marshalled 2x...
    He took 6th qualified 4th. He is also is a killer race announcer...
    http://www.rcsoup.com/2012/02/motorama-2012-results/3/
    Whats in my wallet?
    Jan 2008
    South Jersey
    8,141
    Where are you guys at? That name sounds familiar. Is he sponsored by Kyosho?
    12,369
    http://www.ptraceway.com/Location.html
    I dont know if he is, but if he sent that vid to Kyosho, losi etc, he may get a ride lol
    Whats in my wallet?
    12,369
    Yup, he is a Kyosho team driver:
    http://www.rcsoup.com/2012/02/meet-t...stoltz-kyosho/
    I just went from 6'5" to 2 feet tall. Second is OK, isnt it? LOL
    Whats in my wallet?
    12,369
    Double post...
    Whats in my wallet?
    Jan 2008
    South Jersey
    8,141
    Is that guy bald? For some reason, I think I raced with him in mod truck a few years ago.
