Results 1 to 16 of 16
    Aug 2009
    141
    Wheel alignment - DIY Tools?
    I'm doing some rebuilds on all my cars, also my ERBE and by that I need to set up the wheel hubs correct again. I Know how to do it, I just wonder if there are any DIY guides for making some tools to measure
    and get the correct toe in, camber and so on? I remember seeing someone making some discs to put on the wheel hubs and some tool to measure the degrees.
    Any got som information to how this work, how I can make them and how I use them?
    Aug 2006
    LEICS, England
    4,646
    With a ruler and a protractor and a long straight edge you can set up toe and camber pretty well. If you have a look at the Hudy set up boards, you can make your own set up board. Otherwise I'm pretty sure the lengths that the links should be are listed in the manual or product pages on this site.
    If I remember correctly the RPM Camber guage is fairly cheap.
    If at first you don't succeed, redefine success.
    Aug 2009
    141
    Thank you! It might be in the manual, but not for setting up camber i think
    Aug 2006
    LEICS, England
    4,646
    Camber can be done with a protractor. If you do a quick youtube search there are a couple of good guides.
    Mar 2007
    ashburn, VA
    570
    i use squers like for kabobs. they are cheap. dollor store. tape them to your wheels so they stick way out and you can see how you toe is. or you can tape them so they stick straight up to check camber. quick and easy. i have pics if you dont understand
    REVO 3.3, shumacher fusion .21,TC4, ERBE
    Arkansas
    389
    I did something similar to raqumup…….except I went to my local hardware store and picked up a couple paint stirring sticks. I take off my 17mm hubs because I drilled a ~1/4” hole in the center of the sticks. Then I attach them to the axel and use a standard hub nut to tighten it down.
    I do this on both front tires. The stick will stick out past the front of the truck 8 to 10” and you can easily see the toe.
    I’ve gone a far as to make a layout board with marks on it if I really want to get precise with it.
    Just more food for thought.
    Mar 2007
    ashburn, VA
    570
    Nice idea BlackSheep. that is good for a home sit down take your time alignment, mine is a fast and easy to do at the track alignment.
    Aug 2009
    141
    I did my own setup, CD-R's :
    Thinking about cutting of a inch at the bottom to make a flat surface to adjust from.
    slave lake alberta
    77
    i downloaded a level app on my iphone and hold the iphone up against tire it works real good and the app was free.
    .26 revo
    slash2wd&4w4
    summit
    embe
    2erbe
    132
    Quote Originally Posted by ch3no2jfr View Post
    What's the app called?
    sent from my rooted inspire 4g via Tapatalk
    slave lake alberta
    77
    ihandy level
    .26 revo
    slash2wd&4w4
    summit
    embe
    2erbe
    Cocoa Florida
    3,456
    Round or square set~up(made out of lexan) wheels & an RPM Monster Camber Gauge.
    Cool home made set~up board in this thread.
    http://traxxas.com/forums/showthread...Y-Setup-System
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    Mar 2007
    ashburn, VA
    570
    thats alot of work, but it all depends on why you need your alingment to be correct for, if you are racing for money then you want it to be as RIGHT as you can get it, just bashing, some sticks, tape and your eyes i think would be just fine. JMO
    Cocoa Florida
    3,456
    I've got about $24 in mine & that's with the RPM camber gauge.
    LiPo? Naw NITRO!!
    Mar 2007
    ashburn, VA
    570
    Could you post pics of how you are doing this?
    slave lake alberta
    77
    it works fine for camber i would post pics but it is a real pain in the butt with the photo bucket wish i could post pics right from my pictures to this site with out going to photo bucket.
    .26 revo
    slash2wd&4w4
    summit
    embe
    2erbe
