Results 1 to 13 of 13
    Jul 2011
    13
    gear ratio for brushless slash 2wd
    so im running a velionion system and have steel pinion and spur so they are 32pitch. the spur is 56t. what is the best gear ratio for this motor with a 5000 mah 7cell nimh? currently it is at 8.01
    UK
    1,203
    Depends what you're doing with the car but that ratio sounds very high to me. I've ran 13/54 and 14/54 on 2S Lipo for offroad track racing which worked well. Best to use a temp gun to find the gearing sweet spots for yourself.
    @wormer in the Netherlands
    299
    hi Guido
    what the best gear ratio is for your truck,.. depends on how and where you drive your slash.
    you got a 56T spur
    for hi speed onroad on asphalt go up to 18T pinion
    but on loose sand (beach / dunes ) go down to 12 or even 11
    the velinion doesn`t like the heat... get a fan on your esc. ( a cool esc. is a happy esc. )
    and like what Mr. Wolf said use a temp-gun for the motor..
    if motor gets to hot to touch longer than one second, gear down 2 tooth @ the pinion
    here i got 54T,56T, &58T spur`s
    and pinion`s from 11T, 12T, 13T, 14T, 15T, 16T, 17T, 18T
    the fastest setup for me was 58 / 17 ;-) very fast but short driving time, me 2s 4200 LiPo was down in 11 minutes
    common setup is about 54 / 14
    in very loose sand (construction area we had 54 /12 but that time we raced with Proline Slingshot`s 17 minutes / 2s 4200
    franz
    greetings from holland
    www.rcm-alkmaar.nl
    Jul 2011
    13
    ok thanks. ya i run both road and dirt. i can only use the 56t. but i have a ton of pinions. i will watch the temp. what is a good temp?
    UK
    1,203
    The Velineon motor's rated to 200F without damaging but most try to keep it under 180F. I'm more conservative and keep it under 170F.
    Jul 2011
    13
    oh ok cool. i will do that. im gonna be using lipo as soon as they come in so will gearing change?
    299
    i fried me bearings inside the motor @ 208F / 98Celsius (thats in Celsius 2 degrees below boiling water )
    franz
    www.rcm-alkmaar.nl
    299
    this was inside me VXL
    so gear down and keep it cool
    franz
    www.rcm-alkmaar.nl
    Jul 2011
    13
    holly. ya im gonna temp it today. thanks fo the heads up!
    20
    i just purchased a new velineon motor for my slash 2wd, and i'm using 23/86 gearing but im looking for more torque. the stock gearing was the 19/90 which didn't do anything. however, i'm looking for a happy medium for dirt and street, moreless dirt. any referencs would be great.
    Jan 2010
    86
    bump, with the same question as mrman above...
    South of St Louis
    5,986
    Quote Originally Posted by franzD1 View Post
    Ouch!! I keep my motor temps below 160F. When temps go above 155F I take action and fix the problem; could be gearing, tall tires, too small of a motor etc...
    South of St Louis
    5,986
    mrman, I usually run 23/83 gearing on my velineon setups on both 2s and 3s for street running; I don't go off road much with my trucks except at the track. Some guys gear down from their 2s gearing for 3s but I don't. I think 23/83 is a good all-around gearing for the velineon. You said you ran 19/90 but that didn't do anything for you... If I ran off road I'd probably gear my truck at 18/83 or 19/83.
