Results 1 to 3 of 3
    Dec 2008
    87
    Turn Buckle Wrench
    What do you use to change the length of your turnbuckles? The wrench that comes with the truck
    is so hard to use and doesn't grip on it correct and you can only get about a quarter of a turn.
    thanks for your input.
    Southeast Michigan
    294
    With any other 4mm wrench it's not like you'll get any more travel...
    Plus, when you adjust camber, 1/4 of a turn could be about 1/2 degree (probably a bit less, but you get the point)
    Slash 4x4, Slash 2wd, Circuit, and B4.1 FT
    Feb 2010
    El Sobrante, Ca
    5,193
    The wrench that you use to tighten the slipper will also work.
    Slash 4x4 SCT 2400
    Slash Ultimate MMP 2400
